ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
A friend gave me a hitch for my jeep. Problem is when I put the 4 bolts in, the exit side holes are about 3/8" too low. I am looking for a steel cutting bit for my hand drill or drill press that can cut a slot the 3/8" I need.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Unless you have a milling machine, you are better off drilling a second hole and then cutting the channel with a dremmel. You will have a slot that my be longer then you need, but a drill bit is likely to wander into the original hole otherwise.
The other option is ovaling the hole with a carbide burr or a die grinder. Zach |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 12:12 AM |
