How do you remove the window crank, then how do you put it back on |
mistro |
Jun 17 2005, 08:38 PM
Member Group: Members Posts: 148 Joined: 12-March 04 From: Highland Park, IL Member No.: 1,786 Region Association: None |
I need to remove two black mismatched window cranks and replace with some shiny chrome ones. How do I remove the existing cranks? TIA Rgds, Michael
mihai914 |
Jun 17 2005, 08:43 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
Just pull on the plastic covering of the crank on the round part (not the turn knob), once unclipped, you should see a phillips screw, that's it.
ClayPerrine |
Life's been good to me so far..... Group: Admin Posts: 15,544 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you peel back the plastic cover, you will see a phillips head screw. Just remove it and the crank will pull off.
If you are really anal, make sure the window is rolled up, and then when you reinstall the crank it should point forward and down at a 45 degree angle. (I am picky about the angle of my crank (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) ) |
jet1 |
Jun 17 2005, 08:46 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
If I remember correctly, they should be held in place with a screw. Just pry off the plastic cover.
jet1 |
Jun 17 2005, 08:47 PM
Ha! I am way too slow!
tod914 |
Jun 17 2005, 09:49 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
If that fails, try a shot of adrenelin and a crowbar.
Lo-Fi Version | Time is now: 18th June 2024 - 05:39 AM |
