/6 throttle linkage and bell crank, I need a picture |
Dr Evil |
Jun 18 2005, 11:53 PM
Send me your transmission! Group: Members Posts: 23,034 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am trying to fit my throttle, and bell crank and I need a pic to show me how it all goes together. I think that my bell crank will not work. It is from a 911. Any info?
Dr Evil |
Jun 18 2005, 11:59 PM
OK, I found the pic that I was looking for ( in a previous thread of mine (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) )
I still need to find an OE crank, though. Mine turns the wrong way. Maybe I can heat it and change its direction? Attached image(s) |
Dr Evil |
Jun 19 2005, 12:03 AM
Here is mine
Attached image(s) |
McMark |
Jun 19 2005, 12:38 AM
Dr Evil |
Jun 19 2005, 10:05 AM
I'm hoping that it is low temp welded. I am gonna try Map gas first and a wrench. Then I can see about brazing it on. If not, I'll have to have one of my machineist friends do it. AA lists new ones for $196 (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Dr Evil |
Jun 19 2005, 12:23 PM
Ok, here is the latest. I used the MAPP gas and heated the weakest looking joint until red hot. It broke free and I rotated it to the position necessary.
Now the problem I have is welding it in the new position. Is there a welding rod that I can use with the MAPP gas? I figure that there must be as I heated the joint up enough to break it loose. I tried plumbing solder, but it is not adhearing to the two pieces very well. |
Eddie Williams |
Jun 19 2005, 01:37 PM
Senior Member Group: Members Posts: 822 Joined: 30-December 02 From: Nederland, TX Member No.: 55 Region Association: None |
sounds like you need a brazing rod
Dr Evil |
Jun 19 2005, 01:41 PM
I just bought one, but I am concerned that the MAPP gas will not be hot enough. Will it?
Dr Evil |
Jun 19 2005, 02:01 PM
Its not pretty, but where the metal was thinner around the tube it flowed nicely as there was less metal to wick away the heat.
It is cooling now, slowly to make a stronger bond. I'll take some pics. $3 for brazing rod sure beats $196 for a new crank (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) |
Red-Beard |
Jun 19 2005, 02:15 PM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
MAPP gas is perfectly hot enough for brazing. Brazed joints aren't the strongest thing in the world. I'd find someone who can weld a couple of little points onto that guy. Any muffler shop could do it for $5 or a beer. (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Dr Evil |
Ta da!
Attached image(s) |
Dr Evil |
Jun 19 2005, 02:18 PM
They were brazed to begin with, though. It should be plenty strong as the springs in my throttle assy are not that thick (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Besides, I wanted it NOW. Who wants to wait for a muffler shop? |
Trekkor |
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
And here's the cool one... (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif)
If it works, and YOU like it, you don't have to worry what anyone else has to say about it...Ha! KT ( No pic of my bell crank to be posted here ) |
Aaron Cox |
Jun 19 2005, 02:19 PM
cool deal.
does it run yet? |
Red-Beard |
Jun 19 2005, 02:24 PM
Patience my son, all will be revealed in time. J You're welcome for the MAPP Gas...Did I leave the brazing rod and the brazing flux too? (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
Dr Evil |
Jun 19 2005, 02:29 PM
Nope, I had to buy the rods. $3 and it is pretty strong, too.
Dr Evil |
Jun 19 2005, 11:29 PM
New problem (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
I have my crank oriented as the picture shows, but the ball coupler side that the throttle cable attaches to binds on the tranny side. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I am either gonna put a larger stud on the tranny and space the crank out, or re weld the throttle linkage side farther outboard. 1 forward, two back.....I need to learn to move forward by walking backwards (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Lo-Fi Version | Time is now: 26th December 2024 - 10:50 AM |
