adolimpio |
Art ![]() ![]() Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States ![]() ![]() |
I have a 73 1.7 in excellent condition.
The only things that are not original are a luggage rack and the 1.7 was replaced with a stock, field injected 2.0. The 2.0 runs great, but I have the original, numbers-matching 1.7 and was wondering, if this were yours what would you do? 1. Leave it as-is, with the 2.0 installed and just stick the 1.7 in the basement 2. Rebuild the 1.7 as a stock 1.7 3. Rebuild the 1.7 with a larger bore, and if so what size 4. Rebuild the 1.7 with a 2.0 crank and rods as a stock 2.0 5. Rebuild the 1.7 with a 2.0 crank and rods as a 2056 Budget is not large, but reasonable. I guess the big question is how much value is there is keeping the numbers matching? I could not verify the transmission number, but it's in the correct range. I do plan to stick with fuel injection. Thank you for your pearls of wisdom! |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
#1
Unless the numbers matching thing keeps you up at nite. Then #2 and sell the 2.0 |
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
+3 on leaving it and driving!
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
+4 Definitely option #1. Seems like a no-brainer. Best of both worlds. No reason to deprive yourself of the pleasure of driving a 2.0 and nothing to be gained by having a numbers matching in the car - at least until you are ready to sell. Just keep it on the shelf.
Lo-Fi Version | Time is now: 25th June 2024 - 11:03 PM |
