Big Len |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region ![]() |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
Looks like a very nice Xmas gift for someone to buy for themselves.
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
Seems like a bit much for the street
Maybe good for streets of willow spring s Or baja 1000 (IMG:style_emoticons/default/bye1.gif) |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,441 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
For some reason this comes to mind:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-50-1545167768.1.gif) Every (that) big 4 I've seen has ended up like the above GIF |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
For some reason this comes to mind: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-50-1545167768.1.gif) Every (that) big 4 I've seen has ended up like the above GIF My 2.6 nickies engine has at least 20K+ miles on it. (IMG:style_emoticons/default/biggrin.gif) That FAT shroud won't fit under a 914 decklid. (IMG:style_emoticons/default/huh.gif) |
JmuRiz |
But you were smart enough to use nickies;)
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Beautifully done.
It'll be plenty of fun |
infraredcalvin |
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,531 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California ![]() ![]() |
I beg to differ (as long as you remove the rain tray), this is in my (new to me) Xmas present... (IMG:style_emoticons/default/biggrin.gif) ![]() ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
It's too bad our 914's don't show off the fan like a 911/912 does.
Attached image(s) ![]() |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
I am glad they don't that means the engine is in the correct position in the car.
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,957 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
That's allot of coin for a 4cyl build.. I have never ridden in hot type 4 914 but I bet it's fun.. What kind of longevity do you get from that?
DickSteinkamp |
Senior Member ![]() ![]() ![]() Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None ![]() |
It's too bad our 914's don't show off the fan like a 911/912 does. 912s don't... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.stoddard.com-20876-1545267338.1.jpg) |
914forme |
912E did
DickSteinkamp |
912E did I always thought they looked like this one... (IMG:http://www.914world.com/bbs2/uploads_offsite/carsforsale.sportscardigest.com-20876-1545274809.1.jpg) ...but I guess the little blower at the lower rear qualifies. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
It's too bad our 914's don't show off the fan like a 911/912 does. That's a view we all miss with the 914,tarted up my "6" fin etc but don't forget its spinning there ….chipped a long nail when tuning mine,could have been a digit gone. Message to self make the firewall opening bigger for those 6k timing checks :sawzall (IMG:style_emoticons/default/lol-2.gif) Why will this motor be a timebomb ? ,check on Fat's past rep ...very strong builds in offroad and streetable t4 motors for a very long time. Those TQ numbers are great @ lower RPM and max HP is sensible,sounds like it has to be a good engine,don't see any oil cooler however,is it missing? surely it can't have been on a dyno without it. Read the comments on the auction !!!,one guy replied that it may have an offset ground crank …..really (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) . |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
No oil cooler on the block that I can see. External cooler required. 105mm cast-iron cylinders are not usually good for reliability. One guy did his own engine of similar displacement and had to do a top-end on it every year. I wouldn't be surprised if this were similar; heads refreshed (possibly cracks welded up) and a hone and re-ring every year or so.
--DD |
914forme |
mepstein |
LOL . I was thinking 912 with a six. |
Mark Henry |
That's allot of coin for a 4cyl build.. I have never ridden in hot type 4 914 but I bet it's fun.. What kind of longevity do you get from that? The problem with the build is the iron cylinders, with 103's maybe at best 20K before you need to refresh and install new cylinders. 105's are even thinner. My 2.6 78X102 with nickies has 20K on it now, at 80K (max) I'll refresh the heads, but the P&C's should be good to go. I chose the 102's over the 103 just because the cylinder walls are a bit thicker. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,704 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
LOL . I was thinking 912 with a six. I believe they call that one a "911" ... (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 12:33 AM |
