McMark |
One of my current 2.3 engine builds is getting my fuel injection setup, but he wondered if I could make it work with a future air conditioning install. Since the AC pulley and my trigger wheel use the same location I had to do a little brain scratching. But I came up with a pretty elegant solution (if I do say so myself). I redesigned the trigger wheel to increase the OD so the teeth would extend beyond the pulley. I also opened up the ID to allow it to fit behind the fan hub. Once I had the laser cut pieces in hand (picked them up this morning) I dished the 'back' so the wheel wouldn't hit the case. I also removed a small amount of material from the back face of the fan hub flange also to add clearance to the case, as well as to add a centering boss to keep the trigger wheel centered when I welded it. Came our pretty slick.
I would love to continue on and design a full 4-cyl AC system, but I've got too many other projects to catch up on first. Attached image(s) ![]() ![]() ![]() ![]() ![]() |
BeatNavy |
Certified Professional Scapegoat ![]() ![]() ![]() ![]() Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region ![]() ![]() |
I like it!! (IMG:style_emoticons/default/thumb3d.gif)
aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,428 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
(IMG:style_emoticons/default/beerchug.gif) Looks sweet !!
Lo-Fi Version | Time is now: 25th June 2024 - 11:05 PM |
