db9146 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None ![]() ![]() |
Folks,
Thought I'd share this oil filter comparison for your other cars: https://www.youtube.com/watch?v=iTNJLEV8CG8 |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Yep, Fram is total junk. I used to be a HP-1 lemming and while they do have a heavier can it's still the same junk media inside.
I use Napa gold (1521) on type 4 and for FF remote filter adaptors, 911 and the 996 filter conversion. Mahle, Mann or Bosch are 2nd choice, they're still good filters at a bit cheaper price. I'd also put Wix on the list, but they're not a common brand here. I used to use cheap fram's for break-in, my logic was it was only going to be used for 20-30 minutes to a max of 500 miles. Then I had a POS fram spit out the O-ring seal, sending a stream of oil that hit the 12' ceiling and the wall 32' away, hosing 3 cars in the process. The pressure actually bent mount plate of the filter, never made that mistake again. (IMG:style_emoticons/default/barf.gif) |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
I've always bought OEM filters for whatever car it was for if I could get them at my FLAPS, with Wix being my backup choice. Might be smarter just to start using Wix all the time. I never understood how Fram gets away with that crap. Seems like there should be some industry standard certification that their filters don't meet. I won't even buy their cabin filters because I don't trust the brand in general.
michael7810 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region ![]() ![]() |
Yep, Fram is total junk. I used to be a HP-1 lemming and while they do have a heavier can it's still the same junk media inside. I use Napa gold (1521) on type 4 and for FF remote filter adaptors, 911 and the 996 filter conversion. Mahle, Mann or Bosch are 2nd choice, they're still good filters at a bit cheaper price. I'd also put Wix on the list, but they're not a common brand here. I used to use cheap fram's for break-in, my logic was it was only going to be used for 20-30 minutes to a max of 500 miles. Then I had a POS fram spit out the O-ring seal, sending a stream of oil that hit the 12' ceiling and the wall 32' away, hosing 3 cars in the process. The pressure actually bent mount plate of the filter, never made that mistake again. (IMG:style_emoticons/default/barf.gif) I believe that Wix makes the Napa Gold filter...at least the #1374 I use on my 914. I use Porsche or Subaru on the rest of my cars.. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Funny, I thought I was cheaping out with the Napa gold. There is a Napa distribution warehouse down the road so I was going for convenience since they always had stock.
90quattrocoupe |
Member ![]() ![]() Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California ![]() |
I use Mann or Mahle. Good filters for my German cars.
Most of time I run OEM. I have been going to the same Audi/VW/Porsche dealership since about 1982. I have gone there so much over the years, that I have a employee discount. Most of the time the filter and oil costs me less at the dealership. I used to run a Fram HP1 on my type I back in the 70s, but have not run one on any of my cars since then. Greg W. |
Mark Henry |
I believe that Wix makes the Napa Gold filter...at least the #1374 I use on my 914. I use Porsche or Subaru on the rest of my cars.. Yes, Wix and Napa Gold is the same filter. Funny, I thought I was cheaping out with the Napa gold. There is a Napa distribution warehouse down the road so I was going for convenience since they always had stock. Napa gold are good filters, the LN Engineering 996 filter adaptors and IMS Solution kits use a Napa gold corvette filter. |
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
LN Engineering recommends NAPA Gold for my 997.1
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
NAPA gpld, mainly because it's the closest FLAPS
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
All "other" cars need the same filtration. Unless you are racing and tearing your engine down for a rebuild after each run, you need good filtration. You are getting some good input. Just don't do a K&N or some flaps "high flow" bling.
Lo-Fi Version | Time is now: 27th June 2024 - 02:39 AM |
