3 Pages V  1 2 3 >
> Installing Scheel seats is easy!, No Special Rail needed!
wes
post Jan 27 2019, 05:48 PM
wes
I have a set of Scheel seat that I’m contemplating on installing. I’m wondering as I’ve heard the rails are very hard to find. I need to get the seats out storage but thought I’d check here first as to if it’s possible to use the 914 rail or would I need to adopt? Thanks!
914Sixer
post Jan 27 2019, 06:37 PM
You can use stock rails, HOWEVER you may have to redrill the holes in the seat bases. MOST importantly make SURE you have 914 seats. The 911 ones look real close but the angle is WRONG. Take the seat bases out of car to do test fitting, way less hassle to check stuff.
post Jan 27 2019, 06:38 PM
914-6 GT in waiting
I also have Schell seats for my 914. I was planning on making an adaptor plate to fit the seats on the stock 914 rails and bracket. GTS classics also does reproduction brackets so I might give Stephan a ring and see what he has available.
https://www.classiccarseats.com/brackets.php
@wes
rgalla9146
post Jan 27 2019, 06:51 PM
I have a pair of Sheel/Mann seats.
AFAIK the rails are standard 914 parts.
One of my seats slides easily. The other does not.
I believe care must be taken that the rails are both parallel and on the same plane.
I'll know better in a few days.
wes
post Jan 27 2019, 07:41 PM
wes
QUOTE(914Sixer @ Jan 27 2019, 04:37 PM) *
I’ve had them for several years I was thinking the 911 ones were wider (I thought 21”) and had a deferent head rest. Mine in the back of the headrest are similar shape to stock 914. I need to get them home and check the angle on the back.
GeorgeRud
post Jan 28 2019, 09:26 AM
The Scheel 114 was a perfect fit in the 914 and just used the stock seat rails. Others may need modification to see if they’d fit.
post Jan 28 2019, 10:37 AM
914-6 GT in waiting
QUOTE(GeorgeRud @ Jan 28 2019, 10:26 AM) *
(IMG:style_emoticons/default/agree.gif) scheel brochure from the day said the 114 was built to fit a 914. The other scheel seats like a 300 fit a 911. But from what little I know of scheel seats, the real 914-6GT seat was a 911 seat. Glenn/GMS & company probably have a lot more info.
Mike Fitton
post Jan 28 2019, 11:13 AM
QUOTE(mepstein @ Jan 28 2019, 08:37 AM) *
Yes, Glenn knows these seats. You will need to adjust the rails for the scheel seat you got from me. Had to use a crowbar to get it out of my car, that's how the rear puncture in the vinyl happened. Check with Glenn. BTW that seat used to be George's then it was Brad Mayeur's and I bought it from Garold, Lol!
post Jan 28 2019, 11:58 AM
914-6 GT in waiting
I also picked up Jonathan’s Scheel 300. If it doesn’t fit right in my 914, i’ll save it for my ‘66 build.
falcor75
post Jan 28 2019, 12:32 PM
Ooooh this is very interesting. I'm looking at getting a pair of Sheel replica seats and I'd love to see how it works with the stock 3-point belt, especially the part going over the waist. Any chance that someone can take a seat of themselves in the seat with the belt fastened?
wes
post Jan 28 2019, 03:14 PM
wes
QUOTE(Mike Fitton @ Jan 28 2019, 09:13 AM) *
Wow amazing they have been around! So are the ones I bought from you the 300 series as mentioned used in the GT 6? Wondering did you adjust the rails and still have a fit problem or?
post Jan 28 2019, 03:30 PM
914-6 GT in waiting
QUOTE(wes @ Jan 28 2019, 04:14 PM) *
Wes, Glenn/GMS told me the 6GT seat is very similar to a 300 but no provision for a headrest.
wes
post Jan 28 2019, 04:11 PM
wes
WOW Mike they’ve been around! How did they fit in your car and why’d you pull them out? If it’s true the 300 series had no headrest mine aren’t 300 series as they have headrest. The headrests appear to be shaped on the back for the backpad/window shape. Just brought them home but no time right now play with the fit but anxious too be installing them. Attached Image
wes
post Jan 28 2019, 04:13 PM
wes
The headrest!Attached Image
Mike Fitton
post Jan 28 2019, 04:27 PM
Only had a drivers side seat it was in my 6 and went back to stock when I sold the car last fall.
Larmo63
post Jan 28 2019, 06:41 PM
I found that installing my Scheels was pretty straightforward after I figured out I had to shim the four (small) bolts on each slider with washers. They want to hang up on the vinyl under there if you don't and they get stuck in the car.
Ask me how I know.
wes
post Jan 28 2019, 09:16 PM
wes
Did a dry fitting and all is good perfect fit on rails and the back slant ideal to the backpad. Thanks all!
Maltese Falcon
post Jan 29 2019, 12:11 AM
Never had any issues installing my 114's on to the stock rails. Just did a test fit with the seat rail bolts secured firm-in-place / not tight, guide rails clean and lubed (white lith or vaseline), then slide the seat in place. Once the fit is happy, slowly slip off of the rails out of the car and tighten the bolts. Mine went right back in like EZ job
falcor75
post Jan 29 2019, 12:53 AM
These are the ones I'm looking at but with a headrest. Was just worried about the belts but since everyone seem to agree they fit ok I might go ahead with an order. (IMG:style_emoticons/default/smile.gif)
post Jan 29 2019, 07:04 AM
914-6 GT in waiting
Scheel 114 fit a 914. Scheel 300 fit a 911. 114’s & 300’s have a headrest. Real GT’s don’t have a headrest.
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 19th April 2025 - 12:39 PM
