Firewall Shift rod hole, This doesn't look right |
BPic |
Mar 9 2019, 11:37 AM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I'm working on the engine bay and noticed something didn't look quite right with the shift rod hole in the firewall.
I plan on using the Tangerine shift rod bearing but the firewall hole protrudes out not in. Do I need to add another ring to it? (IMG:style_emoticons/default/confused24.gif) This is the Tangerine Bearing Thanks everyone. |
ChrisFoley |
Mar 9 2019, 12:04 PM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
That's definitely not right. The hole where the shift rod comes out doesn't normally look anything like that.
dr914@autoatlanta.com |
Mar 9 2019, 12:10 PM
914 Guru Group: Members Posts: 7,903 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
needs to have the insert from your old firewall welded in
I'm working on the engine bay and noticed something didn't look quite right with the shift rod hole in the firewall. I plan on using the Tangerine shift rod bearing but the firewall hole protrudes out not in. Do I need to add another ring to it? (IMG:style_emoticons/default/confused24.gif) This is the Tangerine Bearing Thanks everyone. |
BPic |
Mar 9 2019, 02:31 PM
needs to have the insert from your old firewall welded in I'm working on the engine bay and noticed something didn't look quite right with the shift rod hole in the firewall. I plan on using the Tangerine shift rod bearing but the firewall hole protrudes out not in. Do I need to add another ring to it? (IMG:style_emoticons/default/confused24.gif) This is the Tangerine Bearing Thanks everyone. Ahaaa!!!! George what would I do without you. Almost tossed that sucker the other day. Guess it’s good not to like to throw away rust. I’ll tackle this first thing tomorrow. (IMG:style_emoticons/default/piratenanner.gif) Thank you!!! |
BeatNavy |
Mar 9 2019, 02:38 PM
I believe it's this thing. You have to drill out the spot welds and remove it from the old firewall. This is mine after a little "cleaning up," although it looks worse in the 2nd picture than it was.
First pic is it still welded to a section of firewall that I cut out. Removed and ready for welding to new firewall section. |
jimkelly |
Mar 9 2019, 04:20 PM
1 white 1975
2 orange 1972 of area depending on the OD of the hole in your firewall, you may have enough meat left to rivet the tangerine busing on place, but that circular lip will be in your way, either way, it seems. if not, you'll have to grind of that lip and weld in (or rivet in) a piece of flat steel with an OD small enough for you to provide the 3 holes needed for riveting it in i guess. also, i have one, not yet installed. it seems to have to be installed in a specific direction. http://www.tangerineracing.com/transmission.htm Attached thumbnail(s) Attached image(s) |
sixnotfour |
Mar 10 2019, 04:27 AM
914 Wizard Group: Members Posts: 10,438 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
(IMG:style_emoticons/default/idea.gif) side shifter
Attached image(s) |
rjames |
Mar 10 2019, 02:15 PM
I'm made of metal Group: Members Posts: 3,978 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Don’t rivet it in, do it right and weld it.
rhodyguy |
Mar 10 2019, 02:19 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Does the firewall even have the recess the cover piece attaches to?
rgalla9146 |
Mar 10 2019, 04:45 PM
Advanced Member Group: Members Posts: 4,576 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Can you could back the camera up a bit for reference ?
burton73 |
Mar 10 2019, 05:17 PM
burton73 Group: Members Posts: 3,559 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
BPic |
Mar 10 2019, 05:44 PM
The original part when removed has the recessed area and fits the hole on the RD firewall. I did have to the grind the "ring" off but it went in easily. I still have a small bit of welding to fill holes since I ran out of gas. (IMG:style_emoticons/default/headbang.gif)
Thanks everyone for the input I really appreciate the advice. Should have color soon!!! |
Lo-Fi Version | Time is now: 20th June 2024 - 06:24 AM |
