> Throttle Body Rebuild, Pictorial
ctc911ctc
post Mar 25 2019, 09:05 AM
My 17 year old son and I have about 9 months into this project. Our first car, working together. Real 'encounter session'. We have the car running with many learning-experiences along the way.
1. Brake Cylinder - weird installation method, on our 3rd re-try, when will it stop leaking?
2. Valve adjustment - third time was a charm - man can this thing make noise!
3. Pedal assem - Seems OK.......then: let's take it apart and make it smoother.
4. Transmission linkage - All seems in Order, what are those bushings??? Hhhm, rebuild
5. Throttle Control - seems sticky, let's rebuild it! 911Rubber!
Pretty rough looking after 45+ years
Looks pretty grimy down there
Had to chisel this out of the degreaser!
Circuit Card has 20K and 45 years....REPLACE!
All of the parts ready and accounted for,,,,,,,,perhaps we should buy a parts tumbler?
Ready to bolt back into the Silver Beast!
Big difference from where we started
ctc911ctc
post Mar 25 2019, 09:14 AM
I would like to add that I am trying to figure out the best method to clean parts. Currently we are using degreaser and then various wire brushes (steel and synth) which is less than optimum. Comments welcome!
ctc911ctc
post Mar 25 2019, 04:52 PM
Larger and correct orientation of the pictures can be seen by clicking on the top right of the photos that seem to be turned on their side - could not get this 'feature' to stop working.
BeatNavy
post Mar 25 2019, 05:48 PM
How was the shaft inside the TB? They have a tendency to wear and wobble a little, and then you do not get a reliable, consistent closed throttle position. The fix is to bore it out slightly and insert bushings.
Glad you're having fun with your son (IMG:style_emoticons/default/smile.gif)
worn
post Mar 25 2019, 06:37 PM
can't remember
QUOTE(ctc911ctc @ Mar 25 2019, 07:14 AM) *
I have used wire brushes on a Dremel type tool. It is that time of year again folks for me to say those wire brushes can spray out high speed wire arrows. I know one of them added a piercing to my nose. Had it been my eye... but I was wearing goggles. I know that you would have been wearing them too. We all go to such great lengths to roll back the clock on the toy cars of yesteryear. Good for us, but be safe out there.
Mark Henry
post Mar 25 2019, 07:10 PM
that's what I do!
QUOTE(ctc911ctc @ Mar 25 2019, 11:14 AM) *
I use pinesol great on the aluminum , but don't use it on the brass it doesn't hurt it but turns it black, also pinesol will strip cad plating.
draganc
post Apr 3 2019, 08:40 PM
FYI, in regards to cleaning options; I just cleaned my 30 year
old S&S carb in my ultrasonic cleaner, submerged in a 1:1 solution
of simple green “HD” and water.
After only 1hr at 60C the parts look like NEW!
https://simplegreen.com/products/pro-hd-cleaner-degreaser/
Valy
post Apr 4 2019, 02:16 AM
Where did you get the circuit card from?
ctc911ctc
post Apr 4 2019, 07:52 AM
914rubber
QUOTE(Valy @ Apr 4 2019, 02:16 AM) *
Mikey914
post Apr 4 2019, 09:18 AM
The rubber man
we have the
Early 1.7 - 4 pin connectors (on the TPS housing)
https://900designs-container.zoeysite.com/1...4-pin-connecter
Some solderng requires with these
late 1.7 - 5 pin connectors
https://900designs-container.zoeysite.com/1...pin-connector-1
and the 2.0
https://900designs-container.zoeysite.com/2...on-sensor-board
ctc911ctc
post Apr 5 2019, 08:35 AM
What is the model and brand of the Ultrasonic Cleaner???
Many thanks in advance!
CTC911CTC
QUOTE(draganc @ Apr 3 2019, 08:40 PM) *
draganc
post Apr 5 2019, 11:04 PM
I bought following model, which has served me well the past two years:
VEVOR Commercial Ultrasonic Cleaner 6L
https://www.amazon.com/dp/B01HGNYO0U/ref=cm...i_RbdQCb5V7Z3RM
Also, the six liter tank is big enough to clean even most of our 901 transmission parts.
Bigger is better, but it will require also more cleaning solution for the same part.
- Lo-Fi Version Time is now: 4th December 2024 - 08:29 PM
