Highland |
Senior Member ![]() ![]() ![]() Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California ![]() |
So I can't figure out how to get a 27mm socket/torque wrench on this nut. The brake shield fastening feature is in the way with only 2" of clearance.
Do I have to cut the socket to fit or is there one I can purchase? Or does one just use an open ended wrench and approximate the torque? ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Approximate it.
--DD |
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
You can buy a 1/2" drive crows foot that will work, or save $100 and just make sure it's tight
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
If I recall correctly you have to do it at ride height and just lean on it good and hard it has a lock washer so it's not going to come loose
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,682 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
You can buy a 1/2" drive crows foot that will work, or save $100 and just make sure it's tight (IMG:style_emoticons/default/agree.gif) If you put the crows foot at 90* you wont have to recalculate the torques settings. using it straight on you will. It makes more of a difference with a longer extension and a short torque wrench. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
If I recall correctly you have to do it at ride height and just lean on it good and hard it has a lock washer so it's not going to come loose (IMG:style_emoticons/default/agree.gif) I've never taken apart one that has been loose but some of them sure have been tight. |
90quattrocoupe |
Member ![]() ![]() Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California ![]() |
If you are going to use a crows foot, use a flare nut crows foot. It has less of a chance of slipping off the nut.
(IMG:http://www.914world.com/bbs2/uploads_offsite/images.homedepot-static.com-20561-1553798363.1.jpg) |
mlindner |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,535 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest ![]() ![]() |
Just use a box wrench. Even a standard will work.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Two of the most important tools I own is my finely tuned torque arm and my mark 1 eyeball.
Best not to ask what I hang my work light on. (IMG:style_emoticons/default/biggrin.gif) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Rand |
Two of the most important tools I own is my finely tuned torque arm and my mark 1 eyeball. Best not to ask what I hang my work light on. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/lol-2.gif) Yep, another vote for getting used to what torque feels like. |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,963 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
I use blue 242 loctite and just tighten with a wrench.
Lo-Fi Version | Time is now: 26th June 2024 - 12:46 AM |
