Who has built a 103mm+ 66mm stroke engine?, I'm bored and thinking |
Chi-town |
May 1 2019, 10:21 PM
Senior Member Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Ok let me start this with the statement that I'm not looking for opinions or theories on the subject
I want to know has anyone actually done it? I understand the bore to stroke ratio is over square I understand that it won't have any low end I'm not looking for reliability or 50k miles from it Yes I know the heads will need worked and I'll need a spicy cam to really make it zing. Have you built one? How did it run? How long did it last? Where did you get the P&C kit from? I have a spare 1.8 that I'm willing to invest in just to see what happens. |
Steve |
May 2 2019, 12:24 AM
914 Guru Group: Members Posts: 5,682 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I had a 103mm x 71? 2 liter crank? The kit came from European Racing in the late 70’s. I had a 3/4 cam in it and dual 44 Weber’s. It sucked a valve before it made it to 10k miles. Over hauled it and then it broke a ring before it made it to 10k miles the second time around. It was very fast. Ran hot and I had to add an oil cooler. I jury rigged one to the engine lid with a fan. Later the car got rear ended on the avenue. It was totaled, but I was able to buy back the motor and sell it.
ChrisFoley |
May 2 2019, 05:27 AM
I am Tangerine Racing Group: Members Posts: 7,958 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I had one 20 years ago. I bought it already assembled and rebuilt it to cure oil leaks and other assembly issues.
I used it in my street car and then in my race car before selling to someone else. The cam made power from 4500-7500 rpm, and had nothing below that, so leaving stop signs into traffic required a clutch dump. It was the most powerful engine I've ever had in my race car. I think dyno numbers were around 200 peak hp. I reached 125mph at the end of the front straight at Summit Point during a PCA club race around 1999/2000. Edited to add: mine was 102 x 66. |
rhodyguy |
May 2 2019, 07:01 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,188 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
P/C are going to run $3680. WOW. Case work? Extensive. Heads, rods.. Better have ALL of your ducks in a row BEFORE you put the trigger. Don't forget the exhaust system that will support the build. You're going to spend a lot of $. A LOT! How do you intend to feed this engine fuel?
Chi-town |
May 2 2019, 08:38 AM
I found a NOS set for less than $400, that's kinda the reason it peaked my interest.
The rest is easy/cheap/plentiful as it's still just a type 4 VW engine. @ChrisFoley thank you! I expect it to perform exactly as you describe. |
Lo-Fi Version | Time is now: 21st September 2024 - 06:57 PM |
