Wadesbrain |
Newbie ![]() Group: Members Posts: 29 Joined: 29-April 19 From: Mount Bethel, Pa Member No.: 23,073 Region Association: North East States ![]() |
For my build I'm looking at replacing the whole wire harness. I'm thinking about
having kroon build one for me. They sell a 914-6 but I dont see a -4 listed. Does anyone know the difference? Is there another option for a whole new body harness? |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,918 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Lots of differences in the wiring harnesses. NOT interchangeable. Just about every year model of all the versions are different.
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,331 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
The six was built for carbs, left side ignition and a couple other small differences. Most people just use the original harness and repair as needed. Kroon is about $2,500 and only makes the six harness. 914rubber is doing FI engine harnesses and they need replacement more often due to the heat from the engine. Aase had some nos 914-4 chassis harness for a ‘71. Restoration design is making chassis harness but it’s not first on their list right now. If your existing harness is no good, you can put a WTB on World and usually get a decent one for $75-200.
(IMG:style_emoticons/default/welcome.png) |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,578 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
What is wrong with your harness ?
How 'converted ' do you want your car ? My GT project is a '75. The original harness came with the car but had been partially painted when the car color was changed.....not easy to fix. It was also in two pieces. Next came various and difficult issues adapting it to a correct 6 steering column and ignition switch...and three speed wipers...and carbs...and different alternator...and relay board. Too much electricity for me. My choice was easy. I've had a used OE 6 chassis harness salted away for years. If you can do it get a repro harness. I feel it will be easier to adapt a 911 column, ignition switch and directional and wiper/washer switches. If you're doing a 'simple' conversion take Marks advise....find a good used 4 harness. |
mepstein |
What is wrong with your harness ? How 'converted ' do you want your car ? My GT project is a '75. The original harness came with the car but had been partially painted when the car color was changed.....not easy to fix. It was also in two pieces. Next came various and difficult issues adapting it to a correct 6 steering column and ignition switch...and three speed wipers...and carbs...and different alternator...and relay board. Too much electricity for me. My choice was easy. I've had a used OE 6 chassis harness salted away for years. If you can do it get a repro harness. I feel it will be easier to adapt a 911 column, ignition switch and directional and wiper/washer switches. If you're doing a 'simple' conversion take Marks advise....find a good used 4 harness. Rory - I'm not sure the OP is doing a conversion. |
rgalla9146 |
What is wrong with your harness ? How 'converted ' do you want your car ? My GT project is a '75. The original harness came with the car but had been partially painted when the car color was changed.....not easy to fix. It was also in two pieces. Next came various and difficult issues adapting it to a correct 6 steering column and ignition switch...and three speed wipers...and carbs...and different alternator...and relay board. Too much electricity for me. My choice was easy. I've had a used OE 6 chassis harness salted away for years. If you can do it get a repro harness. I feel it will be easier to adapt a 911 column, ignition switch and directional and wiper/washer switches. If you're doing a 'simple' conversion take Marks advise....find a goodhttp://www.914world.com/bbs2/style_images/L11E/folder_rte_images/blackdot.gif used 4 harness. Rory - I'm not sure the OP is doing a conversion. OH !.......never mind. (IMG:style_emoticons/default/sad.gif) .....my one track mind. |
mepstein |
I had sent a 914-4 harness to Kroon but he decided not to build them. Just the 6.
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
Contact member timmy2 on Pelican,he could copy yours or repair it for you ,pretty sure he is doing 911 ones,as long as yours is intact he could do it.
Repairing it is and option if you are good with that sort of thing however he will have all the correct coloured wire etc. Give it a try,could well be cheaper than $2.5K and really knows his stuff,good luck. |
peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
Right now we are focusing on remaking the 911 harnesses. But I can do repairs on existing harnesses that have all the /6 specific components. We just ask that you send your current harness to us.
Pete RD |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,508 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Check with Jeff Bowlsby. I had him refub the FI harness for 7 of 9. Worked flawlessly.
Lo-Fi Version | Time is now: 22nd June 2024 - 07:36 PM |
