boiledcabbage |
Member ![]() ![]() Group: Members Posts: 50 Joined: 23-May 05 From: Ottawa, Canada Member No.: 4,131 ![]() |
how do I disconnect them - just pull the plugs off - anything to worry about or just pull hard ? I don't want to damage them...thx for any advice
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
If you pull off the electrical connections they won't fire.....be careful as they are hard to find replacements and they are brittle from age and heat. Same with the rubberized boots that cover them.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
D-jet (1.7 and 2 litre) you just pull them out, taking care not to damage the rubber boots. L-jet (1.8) has little wire clips which should removed with a little pick tool before you unplug the connector. PITA. BTW. The Cap'n
Lo-Fi Version | Time is now: 20th June 2024 - 06:23 AM |
