> 914-6 wiper motor question
mb911
post Jun 2 2019, 10:32 AM
As I work on my -6 clone I was wondering what most use for the wiper motor? I swear someone mentioned using a 944 motor??
rgalla9146
post Jun 2 2019, 01:15 PM
What harness and switch are you using ?
If a 6 or 911 switch use a 911 3 speed motor adapted to your 914 wiper
rack.
post Jun 2 2019, 02:27 PM
914-6 GT in waiting
I didn't realize the 6 switch needed a 6 motor. Will the 914-4 motor work?
sixnotfour
post Jun 2 2019, 02:45 PM
QUOTE(mepstein @ Jun 2 2019, 02:27 PM) *
3spds baby (IMG:style_emoticons/default/driving.gif)
but ya you can and make it interval option
rgalla9146
post Jun 2 2019, 05:08 PM
Sixes always had a 3 speed wiper like a 911
Choose a 911 motor that is configured like the original 914 one.
There are versions with the 'snail gearbox' on one side and others with it on the
opposite side.
Are you adapting a 911 steering column and switches ?
mb911
post Jun 2 2019, 05:20 PM
Yes I am using an early 911 switch and happen to have an extra 944 motor and thought that may work..
bbrock
post Jun 2 2019, 05:57 PM
QUOTE(mb911 @ Jun 2 2019, 05:20 PM) *
Stealing parts from your son's car is not "extra." (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/biggrin.gif)
burton73
post Jun 2 2019, 06:01 PM
burton73
QUOTE(mepstein @ Jun 2 2019, 01:27 PM) *
I had a short in my factory 6 wiper in #41 and Eric had to put in parts from a 66 911 or early 911. This was not an easy find.
Bob B
Mark Henry
post Jun 2 2019, 06:13 PM
that's what I do!
Damn another thing to collect (IMG:style_emoticons/default/dry.gif)
I have a wiper motor from a '76 911.....Yay? nay? (IMG:style_emoticons/default/unsure.gif)
914Sixer
post Jun 2 2019, 08:18 PM
Use a 914 rack and put the later 911 3 speed motor that looks just like the 914 2 speed. Wire from there. -6 motors are unique to themselves.
Mark Henry
post Jun 2 2019, 09:29 PM
that's what I do!
Thanks ...now to find where I put it.
porschetub
post Jun 3 2019, 12:31 AM
Ben ,go for the 914 drive gear and Boxster motor,good upgrade,I think Mcmark detailed it a ways back,seemed pretty easy,sorry cant find the link.
I bought a Boxster motor to do mine,another future job (IMG:style_emoticons/default/rolleyes.gif) .
Gary
post Jun 3 2019, 03:54 AM
McMark's Wiper Motor Conversion
mb911
post Jun 5 2019, 07:20 AM
Just an update the 944 motor is 3 speed.. Confirmed this morning.
racerbvd
post Jun 5 2019, 04:24 PM
QUOTE(914Sixer @ Jun 2 2019, 07:18 PM) *
True, and if you are lucky enough to find one, it won't be cheap. A$k me how I know (IMG:style_emoticons/default/beer.gif) Attached Image
porschetub
post Jun 5 2019, 08:49 PM
QUOTE(mb911 @ Jun 6 2019, 01:20 AM) *
Yes I think you will be ok ,the 944 one has a good speed on full ,appears there is a lot of other motors they may fit within the VW group when they went to 3 speed,if adding to a 911 switch this is an easy option with wiring matched up.
I see no point in replacing a motor @ this point unless it works better,the 914 one is rather (70's) slow (IMG:style_emoticons/default/sad.gif) .
mb911
post Jun 6 2019, 05:12 AM
I am doing the complete 911 /left hand ignition so now is good enough time as any to do the swap..
ClayPerrine
post Jun 8 2019, 05:57 AM
Just buy a 911 wiper motor setup. Set the 911 wiper rack next to the 914. You will see that the tubes that pass the arms through the cowl are longer on a 911. So take the 911 wiper rack apart and shorten the tubes to the same length as the 914 rack. Then put the shafts and arms from the 914 rack into the 911 rack. Use the 911 motor.
Or, just get a 964 wiper rack assembly. It will bolt right into the holes on the 914, and it sits much closer to the cowl on the underside. You will have to make a support for the motor though.
- Lo-Fi Version Time is now: 5th January 2025 - 03:03 AM
