Joshlm |
Newbie ![]() Group: Members Posts: 3 Joined: 16-March 19 From: Clovis CA Member No.: 22,964 Region Association: Central California ![]() |
So 2 days ago I was driving my 914, was doing fine all day and then I came home and about 20min later I went to start it and nothing. It’s not cranking at all. I charged and checked the battery, it’s fine (12.7v , Under load it’s 12.2v). I tried tapping the starter solenoid and nothing. I used screwdrivers to check and when I made a contact between 2 points on the solenoid I got a buzzing sounds does this mean my starter is fine? The car did not crank, but I heard the starter operating. When I made a connection between the actual starter and the solenoid I just got sparks.
With the key on accessory mode the radio and electronic work. Recently the generator light went out but I haven’t had a chance to look at it. I checked the voltage at the solenoid and it was fine (12.7). I can’t check my earths right now because my multimeter doesn’t have the continuity option (it’s the $7 harbor freight one). Does 72 have the under passenger seat relays? I didn’t see anything under the seat in my car. What do I need to test / check on my relays in the engine compartment? And does that yellow wire need to be connected to the solenoid? I didn’t see anywhere it would have mounted. Thanks in advance 72’ 1.8 ![]() |
Joshlm |
mkinne |
Newbie ![]() Group: Members Posts: 36 Joined: 30-November 03 From: Alta Loma, CA Member No.: 1,406 ![]() |
Looks like the yellow wire is hanging loose in your first pic.
Shouldn't it go to the spade terminal (hidden in your pic) at the top of the solenoid? -M |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
You need to clean your relay board and all that goes with that. The leaf is a nice touch.
ndfrigi |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California ![]() ![]() |
also check your ignition key/switch
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
(IMG:style_emoticons/default/beer3.gif) Rands photo
Attached image(s) ![]() |
Joshlm |
I got it figured out, it was that yellow wire. Next I will do a good electrical cleaning. Thanks!
mzalanka |
Member ![]() ![]() Group: Members Posts: 116 Joined: 11-July 11 From: Portland, OR Member No.: 13,300 Region Association: None ![]() |
I got it figured out, it was that yellow wire. Next I will do a good electrical cleaning. Thanks! Also - just to mention - often these cars have hot start issues caused by increased resistance in the 50ish year old harness when warm. The symptom is failure to crank when warm, with normal cranking after the engine cools. There are other options out there but - the Bosch hot start relay - WR1 - will fix this and is an easy 15 minute install. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,708 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
I got it figured out, it was that yellow wire. Next I will do a good electrical cleaning. Thanks! Also - just to mention - often these cars have hot start issues caused by increased resistance in the 50ish year old harness when warm. The symptom is failure to crank when warm, with normal cranking after the engine cools. There are other options out there but - the Bosch hot start relay - WR1 - will fix this and is an easy 15 minute install. No appears not,its a lightweight cure,member Mark Henry got me on to his cheap Ford relay install,works great ... check it out . Appears you have a rebuilt starter..some have had issues with these. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
I got it figured out, it was that yellow wire. Worst thing about 914's: Archaic Spade Connectors. The lack of water proofing and positive locking is simply hilarious as compared to modern vehicles. Best thing about 914's: Archaic Spade Connectors. Available everywhere and easy to fix. |
Superhawk996 |
Also - just to mention - often these cars have hot start issues caused by increased resistance in the 50ish year old harness when warm. The symptom is failure to crank when warm, with normal cranking after the engine cools. There are other options out there but - the Bosch hot start relay - WR1 - will fix this and is an easy 15 minute install. Also worth mentioning that before you resort to hot start relay and other modifications, a 0 ohm connection between engine/trans to the body (i.e. chassis ground) is a must. You can have the best wiring up top but a high resistance ground at the ground strap will defeat you. I've seen cars without a ground strap between the body and the engine and then all sorts of crazy wiring mods and secondary relays added as band aid's. Simply fixing the ground strap and reverting to OEM wiring was the solution. Keep in mind, without a ground strap, electricity will find alternate ground path's, like your clutch cable. Using clutch cable a a ground quickly leads to clutch cable failure. |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
I feel your love Jeff. (IMG:style_emoticons/default/poke.gif)
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
ValcoOscar |
Garage Life ![]() ![]() ![]() ![]() Group: Members Posts: 2,427 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California ![]() ![]() ![]() |
I got it figured out, it was that yellow wire. Worst thing about 914's: Archaic Spade Connectors. The lack of water proofing and positive locking is simply hilarious as compared to modern vehicles. Best thing about 914's: Archaic Spade Connectors. Available everywhere and easy to fix. You are so correct, I've learned. Now I stock these at home along with shrink tubing. Oscar ![]() |
Rand |
Andy you crack me up. Jeff knows I love him. We have WA blood.
Lo-Fi Version | Time is now: 26th June 2024 - 03:26 AM |
