9144me2enjoy |
Member ![]() ![]() Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest ![]() |
I’ve decided to pull the plug and upgrade to a Rennshift Shifter for my 901 side shift transmission, even though not a cheap upgrade. They show a stick length option of stock or 2” longer and Aluminum or Anodized Black. Suggestions on the stick length? I know the finish is just personal preference. Thanks
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I did one in my SC. I did a tall stick and then made it even taller with a Wevo shift knob that attached on the tip of the stick, rather than the ones that slide down over the stick. I like it a little closer to the wheel.
Attached thumbnail(s) ![]() |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,341 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
All personal preference but you won’t regret spending the money. Don’t sell your stock shifter without removing the shift rod coupler at the bottom.
9144me2enjoy |
Thanks for the advice! Appreciate it....
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I love my Rennshifter. Worth it. Make sure trans is up to snuff, though. If not, the Rennshifter can help you find and exacerbate problems (IMG:style_emoticons/default/wink.gif)
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
I had to be one of James' first customers. That and Patrick Motorsports shifter and the gear shift rod bearing kit, tra9146rsr, and my six shifts perfectly. No vagueness with just the right amount of "click into place" feeling. Love it.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I love my Rennshifter. Worth it. Make sure trans is up to snuff, though. If not, the Rennshifter can help you find and exacerbate problems (IMG:style_emoticons/default/wink.gif) (IMG:style_emoticons/default/agree.gif) The trans and all bushings need to be good, also the tangerine console double bushing makes for a real nice shifting package. Just be aware you'll never have the speed shifting of some cars, even with the Rennshift you cant slap it into the gears hard, you have to have a gentle touch and glide it through the gears. Don't force it, more like you let it find it's own path, forcing it you can still grind the gears. Set it up so it's naturally in plain for 2nd-3rd, then it should be just a slight side pressure for 4-5th or 1st. I never downshift to 1st with the auto reverse lockout you should have to jiggle it side to side in neutral before it will go in. It took me a bit of adjusting to find it's sweet spot, I now have it on the short shift adjustment. If you're tall you will want the extra bend to move it slightly back towards you. |
9144me2enjoy |
That’s some great advice which I will take to heart, thanks again.
RickS |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None ![]() |
Really enjoy mine but it took awhile to dial in. A long while, but it was worth it.
horizontally-opposed |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,435 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None ![]() ![]() |
I go back and forth on whether I need/want an RennShift.
For: Lots of good feedback here, and the 914's shifter has always been one of its weakest links. Against: 1) My side shifter + a mere Weltmeister short-shift + all new bushings + straight shift rod for six conversion shifts really nicely; 2) not sure I love the RennShift's larger base in the interior, which doesn't look bad by any means, but doesn't look like part of the original design either; 3) occasional griping about problems exacerbated, etc (hard to tell is this is 100% user error/car issues/etc...but suspect it is). Which just takes me back to 1). |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I go back and forth on whether I need/want an RennShift. Against: 1) My side shifter + a mere Weltmeister short-shift + all new bushings + straight shift rod for six conversion shifts really nicely; 2) not sure I love the RennShift's larger base in the interior, which doesn't look bad by any means, but doesn't look like part of the original design either; 3) occasional griping about problems exacerbated, etc (hard to tell is this is 100% user error/car issues/etc...but suspect it is). Which just takes me back to 1). If what you have works for you, then rock what you have. Zach |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
I had a Welmeister short shift that work real good too, with the center console and recently went to the Renshift. I could make the Weltmiester work well but the Renn does not need a special trained hand to make work, the Renn works every time for all users. Looks good with the console or you can boot the shifter to hide it if needed. Would not change back
Luke M |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,381 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States ![]() ![]() |
I had a Welmeister short shift that work real good too, with the center console and recently went to the Renshift. I could make the Weltmiester work well but the Renn does not need a special trained hand to make work, the Renn works every time for all users. Looks good with the console or you can boot the shifter to hide it if needed. Would not change back I have a Rennshifter and plan on running a center console as well. Any pics of the installation ? I know the center console needs to be slightly modified to fit over the shifter housing. |
tailwind22 |
Member ![]() ![]() Group: Members Posts: 89 Joined: 7-November 17 From: Moses Lake, WA Member No.: 21,583 Region Association: Pacific Northwest ![]() ![]() |
I had a Welmeister short shift that work real good too, with the center console and recently went to the Renshift. I could make the Weltmiester work well but the Renn does not need a special trained hand to make work, the Renn works every time for all users. Looks good with the console or you can boot the shifter to hide it if needed. Would not change back I have a Rennshifter and plan on running a center console as well. Any pics of the installation ? I know the center console needs to be slightly modified to fit over the shifter housing. I also have a center console and am at the install point and was wondering what the floor of the center console will look like after install. Pics from someone with a center console would be great! |
mepstein |
I had a Welmeister short shift that work real good too, with the center console and recently went to the Renshift. I could make the Weltmiester work well but the Renn does not need a special trained hand to make work, the Renn works every time for all users. Looks good with the console or you can boot the shifter to hide it if needed. Would not change back I have a Rennshifter and plan on running a center console as well. Any pics of the installation ? I know the center console needs to be slightly modified to fit over the shifter housing. I also have a center console and am at the install point and was wondering what the floor of the center console will look like after install. Pics from someone with a center console would be great! You pull back the vinyl, make the hole about a 1/4” larger that the shifter and then secure the vinyl back in the console with some contact cement. You probably have to make a new boot to fit but that’s easy with a scrap of leather. |
thelogo |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None ![]() |
(IMG:style_emoticons/default/beer3.gif)
My stock shifter is solid as hell But ive been curious about renshift . For me the big /4 made a big difference because i can really use the tall gears to accelerate the car better . Unlike the f1 powerband of the 1.7 I always knew i was lucky i guess since i had the car it always shifts like butter (Tighten clutch cable) and go And does anyone know car speed in mph with 15in tires At 3k and 4k rpm ???? In 5th gear |
Lo-Fi Version | Time is now: 1st July 2024 - 06:00 AM |
