Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I have the room in my weber /6 conversion so I want to add a charcoal canister. I couldn't smell gas with a half tank, but I just filled up and I can smell just a whiff of gas, so I want to try a canister. I have the original plastic type out of my '74.
The can has a big smog hose each end and one end has the small line from the tank, which is the in and out sides? Also what would be the optimal inlet placement with K&N rain hats? |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
There should be an arrow on the body for fuel flow if it is a Bosch.
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
The arrow points to the trash can. (IMG:style_emoticons/default/poke.gif)
Mark Henry |
Why? it's just trapping and burning off some gas vapour? |
Mark Henry |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
There should be an arrow on the body for fuel flow if it is a Bosch. It is a bosch, my eyes must be getting bad, I can't find an arrow. Did you see any Indians? (IMG:style_emoticons/default/av-943.gif) Couldn't resist. (IMG:style_emoticons/default/happy11.gif) |
Mark Henry |
There should be an arrow on the body for fuel flow if it is a Bosch. It is a bosch, my eyes must be getting bad, I can't find an arrow. Did you see any Indians? (IMG:style_emoticons/default/av-943.gif) Couldn't resist. (IMG:style_emoticons/default/happy11.gif) (IMG:style_emoticons/default/huh.gif) Why yes I did... I got gas at the reserve a couple hours ago. It's called the Green Mile, cheap gas, smokes and a weed "dispensary" every 100 feet. (IMG:style_emoticons/default/smoke.gif) |
Rand |
Why? it's just trapping and burning off some gas vapour? I just like minimal. Interesting that I have eliminated the canister and not had vapor problems. Makes me wonder if an additional part will solve the problem? |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
This shows it.
Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
One of those things i regret i removed when i redid the car some 15 years ago. Should have kept that canister.
(IMG:style_emoticons/default/dry.gif) |
914Sixer |
Picture time.
Attached image(s) ![]() ![]() |
Mark Henry |
Picture time. Not the same, VW part number 113 201 823A Pic pulled from an evilbay ad. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.ebayimg.com-26-1565061832.1.jpg) |
SirAndy |
Carl La Fong |
Member ![]() ![]() Group: Retired Members Posts: 137 Joined: 27-March 19 From: west Member No.: 23,000 Region Association: None ![]() |
Mark Henry |
This shows it. Thank you Jeff (IMG:style_emoticons/default/thumb3d.gif) On your drawing it almost looks like it goes to the TB or plenum, it's before the TB in the air cleaner hose correct? So for a /6 with weber rainhats, should I point it straight down a barrel? Or off to the side of one? Or should I do it like the existing breather hole on the side of the hat skirt and pass gas through the filter? (I know.. insert joke) I have to drill a hole in the rain hat. This is just zip tied where I'm thinking of mounting it. I'll just use a simple strap with a wing nut so I can remove it quickly for servicing the battery. The battery is a Odyssey PC680 mounted on it's side. Or maybe I could do it from the other side (IMG:style_emoticons/default/idea.gif) Attached image(s) ![]() |
Mark Henry |
Is it important to mount it on it's side? or does it matter?
I've always seen them mounted horizontal on VW's and 914. |
JeffBowlsby |
Output of it goes to the air filter housing, before the filter. Don't know how it routes with carbs, but I imagine you would need a "T" to split it 50/50 to each carb.
Orientation of the charcoal canister is not gravity specific. Its just airflow through it. |
Mark Henry |
Output of it goes to the air filter housing, before the filter. Don't know how it routes with carbs, but I imagine you would need a "T" to split it 50/50 to each carb. Orientation of the charcoal canister is not gravity specific. Its just airflow through it. Thanks Jeff I think I'm going to look at the other side, then it's not in the way of the battery. It's only a small amount of vapour so I think running it to one carb will be sufficient. I'll drill a hole in the hat opposite of the existing smog hole, the vapour will go through the filter that way. I'll post a pic when I get it done. |
Lo-Fi Version | Time is now: 26th June 2024 - 04:48 AM |
