cassmcentee |
Member ![]() ![]() Group: Members Posts: 180 Joined: 12-July 18 From: Squaw Valley, CA Member No.: 22,304 Region Association: Central California ![]() ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you are pulling all the head studs, first put some Seafoam Deep Creep penetrating oil on them, and if you have time let them sit for a day, and tapping with a brass or plastic hammer will help the oil work. Most of the time you can put two nuts on the top threads, tighten them against each other and use that to back them out. If they are rusty (like yours) this can cause them to break, so I'd carefully add some heat with a MAP or propane torch.
cassmcentee |
If you are pulling all the head studs, first put some Seafoam Deep Creep penetrating oil on them, and if you have time let them sit for a day, and tapping with a brass or plastic hammer will help the oil work. Most of the time you can put two nuts on the top threads, tighten them against each other and use that to back them out. If they are rusty (like yours) this can cause them to break, so I'd carefully add some heat with a MAP or propane torch. Cool, Thank you Perry, I have plenty of time! What about the ones trapped on the head? Add two nuts to the bottom threads to counter the top nut??? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,596 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Soak the threads with penetrating oil (I use PB Blaster), double nut the bottom of the studs, and unscrew the nuts.
Personally, those studs are awful rusty. I wouldn't reuse them. If you choose to get new studs, just lock them with vice grips. Good luck. Clay |
cassmcentee |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,029 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Now I know the double nut trick works well most of the time and is basically free, but, I really love these Snap-on collet stud extractors.
Double nuts sometimes slip and/or don't seem to get enough grip on the threads sometimes. I've resorted to triple nutting a time or two. Overkill for sure, but, I love having the right tool for the job. ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,442 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
wow thats really compact,,I have the older style long collett one,,,
add to cart... |
cassmcentee |
That Stud Extractor looks great!
Just one that feels like it's going to twist... (or worse) Doin' Da Double Nut Slip (IMG:style_emoticons/default/piratenanner.gif) (heated and soaked) Will do the triple nut in the morning (soaking) Just hate putting Vicegrips on anything (IMG:style_emoticons/default/sad.gif) ![]() |
preach |
Ridge Runner ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 27-March 10 From: Live Free or Die Member No.: 11,513 Region Association: North East States ![]() ![]() |
Now I know the double nut trick works well most of the time and is basically free, but, I really love these Snap-on collet stud extractors. Double nuts sometimes slip and/or don't seem to get enough grip on the threads sometimes. I've resorted to triple nutting a time or two. Overkill for sure, but, I love having the right tool for the job. Those are nice. A trick tool I learned about at work is vice grips with a nut welded to the jaws then cut in half. Plenty of clamping power without damaging the threads. |
I really love these Snap-on collet stud extractors. Double nuts sometimes slip and/or don't seem to get enough grip on the threads sometimes. I've resorted to triple nutting a time or two. Overkill for sure, but, I love having the right tool for the job. Nice! Tool envy. That is in fact the best tool for the job. |
ClayPerrine |
If you are not going to reuse the stud, then weld a nut to the stud. I do that for pulling studs out of /4 heads.
Lo-Fi Version | Time is now: 1st July 2024 - 05:23 AM |
