JOEPROPER |
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States ![]() ![]() |
JOEPROPER |
JOEPROPER |
I guess now that the engine is in, I'll need to (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) it into place. (IMG:style_emoticons/default/headbang.gif)
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,160 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
Nevermind-
JOEPROPER |
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
That's a bummer. (IMG:style_emoticons/default/sad.gif) I wouldn't think the bushing would fit right without that piece. Also, the outer lip is needed to hold the dust boot that is supposed to protect the shift coupler.
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() Group: Members Posts: 4,548 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
QUOTE @JOEPROPER I guess now that the engine is in, I'll need to (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) it into place. (IMG:style_emoticons/default/headbang.gif) Joe, Side shift trans? I have a rear firewall section cut out of a car from which that can ba harvested. Bruce |
JOEPROPER |
QUOTE @JOEPROPER I guess now that the engine is in, I'll need to (IMG:style_emoticons/default/sawzall-smiley.gif) and (IMG:style_emoticons/default/welder.gif) it into place. (IMG:style_emoticons/default/headbang.gif) Joe, Side shift trans? I have a rear firewall section cut out of a car from which that can ba harvested. Bruce Thank you Bruce, I have this section that I'm going to use. I'm just looking at it and trying to figure out how to deal with the heater cable tube. This is not a big deal for some people here, but will require some planning for me to do it correctly. |
bbrock |
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif)
JOEPROPER |
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley The rivet holes are on a 1.875" circle so it should be easy to install it over the existing hole. While having the reinforcing piece in place is a nice idea I don't see it as necessary structurally when using my bearing assembly. The aluminum housing features a groove for the boot so not having that on the firewall is no problem either. |
JOEPROPER |
I've never looked at that piece closely, but would it be possible to separate the disc piece from the firewall patch? Is it spot welded on? I think it would be a lot easier to plug weld the disc onto you firewall than to try to cut and butt weld a patch. (IMG:style_emoticons/default/confused24.gif) I didn't think of that. The section behind the disc has a reinforced plate. I'm not sure if this is necessary, and if not, maybe i could just buy the Tangerine Racing firewall bearing setup and rivet it in. @chrisfoley The rivet holes are on a 1.875" circle so it should be easy to install it over the existing hole. While having the reinforcing piece in place is a nice idea I don't see it as necessary structurally when using my bearing assembly. The aluminum housing features a groove for the boot so not having that on the firewall is no problem either. That's all I need to hear. I'll post results after I get the bearing assembly. Thanks! |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Good move. Every review that I've read re: Tangerine's shift bushing, is stellar. Everyone says it makes the 914 shift like a modern car. So, as my Dad used to tell me, "You fell into a bucket of shit and came out smelling like a rose". (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 09:44 PM |
