second wind |
Senior Member ![]() ![]() ![]() Group: Members Posts: 860 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California ![]() ![]() |
Hello gang.....I have just changed out all of the shift bushings in my '73 2.0. I was told that after 1972 that there are no bushings to replace in the shift knob mechanism as there were in prior years. What is the best way to lubricate all those parts under the shift knob boot? Thank you very much.
gg |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
I replaced the shift knob bushings on my 74 2.0
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
Clean the underside. Put it in 2nd gear. Remove the housing bolts and turn the shifter 90*. Remove the the yoke to shift lever bolt. This preserves the current front setting. Inspect the detention plate and lever for wear.
Lo-Fi Version | Time is now: 25th June 2024 - 11:10 PM |
