914 Noid lights |
914 Noid lights |
JeffBowlsby |
Nov 30 2019, 11:04 PM
914 Wiring Harnesses Group: Members Posts: 8,777 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
People always mention using noid lights to troubleshoot the FI. Looking around I see large sets of 6-10 different types, sets real mechanics might need to buy, but they are $30-50 for the set. We don't need all those variations, we need just one or two. Seems to me they should be available individually for ~$5 bucks.
Hello...Mikey? Is there a different light for D-Jet and L-Jet or does the same light work on both? What are yall using? Are they available individually and if so, which one to get and where to buy? Is a noid light overkill, or can a simple test light (the awl point screwdriver handle probe type) or DVM be made to work? |
JeffBowlsby |
Dec 1 2019, 09:33 AM
I found these on amazon. Anyone use these before?
OEMTOOLS 27319 OTC 6266 Attached thumbnail(s) |
Chris914n6 |
Dec 1 2019, 03:22 PM
Jackstands are my life. Group: Members Posts: 3,423 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I could use the Bosch ones too but haven't seen it separately for less than half a whole set.
A DVM reacts too slow to read but will fluctuate letting you know it's being triggered, so technically yes. Also, since injectors click, you could plug in a known working one and either listen or feel. |
bdstone914 |
Dec 1 2019, 10:16 PM
bdstone914 Group: Members Posts: 4,731 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I bought a Harbor freight set for $12.
They work ok. It is just a bunch of different terminal types. I don't think they pick up every pulse. Response seems inconsistent. I had a Subaru fi system that I wanted to check injector signal. Saw these on ebay Attached thumbnail(s) |
Mikey914 |
Dec 2 2019, 12:45 PM
The rubber man Group: Members Posts: 12,741 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
People always mention using noid lights to troubleshoot the FI. Looking around I see large sets of 6-10 different types, sets real mechanics might need to buy, but they are $30-50 for the set. We don't need all those variations, we need just one or two. Seems to me they should be available individually for ~$5 bucks. Hello...Mikey? Is there a different light for D-Jet and L-Jet or does the same light work on both? What are yall using? Are they available individually and if so, which one to get and where to buy? Is a noid light overkill, or can a simple test light (the awl point screwdriver handle probe type) or DVM be made to work? I have a buddy over at Intel that can get me some hookups on stuff. These are pretty inexpensive, sure we could get them made, but if the ones on the market are inexpensive and readily available, no need. Mark |
Lo-Fi Version | Time is now: 22nd December 2024 - 05:34 AM |
