> Oil Temperature Sender (Taco Plate), * New Product *
914werke
post Dec 14 2019, 06:42 PM
OIL its condition & temperature is critical to the health & operation of the T4 motor. (IMG:style_emoticons/default/shades.gif)
Many were fortunate that their cars came equipped from the factory with the components to monitor the temperature of that oil, others were not
Of those that did have the gauge and sender assembly installed, many if not most were plagued by leaks from that area due to its construction. (IMG:style_emoticons/default/headbang.gif)
The factory made the multi-part assembly out of thin gauge stamped steel that was prone to bending under the small torque applied to its fasteners thus resulting in persistent leaks & the nickname for this component the "Taco Plate" (bent into a Taco shape).
Made of billet aluminum here is a solution for replacement of that OE part or installation for cars that never had one in your 914 (411/412 or T2)!
Available w/o sender or as an assembly. HERE
racingredsc
post Apr 5 2020, 08:19 AM
Is this available?
QUOTE(914werke @ Dec 14 2019, 08:42 PM) *
racingredsc
post Apr 6 2020, 09:34 AM
I need everything except sender. Plate,O ring and hardware. Is that everything?
914werke
post Apr 6 2020, 10:07 AM
Yes pretty simple assembly M5 hardware, crush washers, The large O-ring from your blanking plate or OE sender can usually be re-used but is f provided if trashed, sender boot & panduit.
racingredsc
post Apr 7 2020, 01:35 PM
I need the plate w/hardware and O ring. I really need it by Friday. Anyway?
QUOTE(914werke @ Apr 6 2020, 12:07 PM) *
Yes pretty simple assembly M5 hardware, crush washers, The large O-ring from your blanking plate or OE sender can usually be re-used but if trashed is available + sender.
racingredsc
post Apr 7 2020, 01:37 PM
Your store website won't load>
FlacaProductions
post Apr 7 2020, 02:32 PM
Works ok for me just now - 132pm, pacific on Safari/Catalina 10.15
914werke
post Jul 3 2020, 06:35 PM
(IMG:style_emoticons/default/cheer.gif)
Robarabian
post May 14 2022, 10:13 PM
914 A Roo
Rich,
Looked on the website. I need another one of these. Got any?
Robert
914werke
post May 22 2024, 11:31 AM
- Lo-Fi Version Time is now: 2nd April 2025 - 01:56 AM
