63acornwall |
Member ![]() ![]() Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None ![]() |
looking at the interior of door , no obvious screws to remove door panel and top padded rail ? Is there an existing thread for this ?
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
Jett |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest ![]() ![]() |
Door panels are all one piece with screws holding the arm rest(sj and drivers door compartment. Once the arm rests are removed, there are plastic clips every few inches that need to be gently popped out without bending the door card too much. The top bolster portion of the door card has three metal tabs that attach at the top of the door and once you have the plastic tabs free you simply slide the door card up and out.
Added picture to help see what is inside Attached thumbnail(s) ![]() |
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,285 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Both sides, there are 3 screws along the bottom of the armrests, then then there are plastic plugs along F & rear sides that will pop out. then lift vertically to release tangs along the top edge. Of course, the window crank & the recess under the interior lock/opener handle screws need to com out. The window crank plastic cover will lift away for access to the screw under.
914 rubber sells new plastic & silicone bits that will probably break when you pull the door cards away. |
63acornwall |
Thanks guys , that is really quick and helpful .
BTW I am not very skilled with the search engine , it returns a lot more than I can cope with , so appreciate the help ! |
Lo-Fi Version | Time is now: 30th June 2024 - 06:10 AM |
