> Foam and undercoating, How to remove undercoating and foam
kroelofsen
post Dec 23 2019, 12:59 PM
Region Association: Europe
Hi everyone,
Started today to remove some undercoating in the rear wheel arches, see picture...
When using a (blunt) chisel is comes of rather easily. Any advise on removing it in the corners of the arches…? Especially in the rear it is almost impossible to reach the far corners...
I also found the foam in the rear of the panels near the rear lights (yellow circle). With a hook I'm picking it out. Any tips on doing this more easily…?
Till now I did not find any rust. The car is from 12/73 and 1.8 L-jet in olympic blue.
ClayPerrine
post Dec 23 2019, 01:20 PM
That foam was ironically installed to prevent rust. It ended retaining water and causing rust.
I was able to remove it by cleaning off the top layer of sealant, then spraying it with carb cleaner. The carb cleaner dissolves it and it runs out the bottom. You will have to repaint in the fender if you do it that way.
Clay
rudedude
post Dec 23 2019, 02:27 PM
I took a long big welding rod, sharpened a tip on it and scraped little by little until it was all out. Could bend it to the shape I needed at the time. Took a while and hopefully was worth it
Eric_Shea
post Dec 23 2019, 02:41 PM
PMB Performance
Torch.
Superhawk996
post Dec 23 2019, 03:35 PM
QUOTE(kroelofsen @ Dec 23 2019, 01:59 PM) *
Per Jeff Hail recommendation Wurth DBS 3600 with the wire flail wheel simply tears though the factory seam sealer and makes easy work of it. It is pricey but worth it. There are 1/2 price alternatives though Eastwood and one other place (forget the name).
https://www.wurthusa.com/Tools/Air-Tool-Par...Case/p/07033601
All depends on what your time is Wurth (pun (IMG:style_emoticons/default/laugh.gif) ). It tears simply tears though undercoating even easier without damaging the metal below it. Other methods work but this tool as designed for professional use for exactly this task where time = money.
djway
post Dec 23 2019, 11:14 PM
Heat the metal on the other side then scrape off.
Huge mess, time and wear a resperator as I hear this stuff gives off toxins.
kroelofsen
post Dec 24 2019, 01:51 AM
Many thanks for good suggestions, will give it a try…
Happy holidays…! (IMG:style_emoticons/default/santa_smiley.gif)
mlindner
post Dec 24 2019, 08:36 AM
Purchase this from HF, extended angle grinder and a wire brush wheel, cut the 1/4 stud off the wheel and drill hole to fit grinder. I did my entire exterior floor and inner fenders in four hours. Best, MarkAttached Image
Superhawk996
post Dec 24 2019, 10:12 AM
QUOTE(mlindner @ Dec 24 2019, 09:36 AM) *
I like it. The low profile head will have advantages over the Wurth tool in tight quarters. I don't know that I've ever seen that tool in a HF store but I'll be looking next time!
Just be sure to wear a face shield. Spinning a wire wheel at air tool speeds can shed those wires as very dangerous little projectiles.
mlindner
post Dec 24 2019, 10:24 AM
Superhawk996, and I think it was only $25.00. really worked great up in the tight 914 inner fenders.
kroelofsen
post Dec 24 2019, 02:15 PM
The extended angle grinder is really clever, will get one asap... Many thanks for sharing!
kroelofsen
post Jan 2 2020, 12:14 PM
Today I continued working in de rear fenders... I remove from one side the seal sealer and foam. See the big piece I got out...
It wasn't very much sticking to the bare metal... There is no rust to be found luckily! (IMG:style_emoticons/default/piratenanner.gif)
Cairo94507
post Jan 2 2020, 02:13 PM
Michael
Nice. Get that foam out and leave it out. (IMG:style_emoticons/default/beerchug.gif)
mbseto
post Jan 3 2020, 01:20 PM
QUOTE(Superhawk996 @ Dec 24 2019, 11:12 AM) *
I think I'd even want a full face respirator for that...
post Jan 3 2020, 01:31 PM
914-6 GT in waiting
QUOTE(mbseto @ Jan 3 2020, 02:20 PM) *
I've been wearing a respirator (besides a face shield) for cutting, grinding, blasting etc. Trying to keep the nasty stuff out of my lungs.
Rand
post Jan 3 2020, 01:45 PM
Cross Member
QUOTE(Eric_Shea @ Dec 23 2019, 12:41 PM) *
Torch.
Definitely the most satisfying. Burn that garbage out. I ain't wasting wear on abrasive tools and time for that worthless poo.
- Lo-Fi Version Time is now: 27th December 2024 - 05:50 AM
