Steering wheel and center push interchange? |
Tdskip |
Jan 30 2020, 02:15 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Hi guys - hope everyone having a good week.
I have several steering wheels and several centers, all separate. Other than just trying to fit them to each other are there part numbers / stamping that indicate what belwkngs together? |
914Sixer |
Jan 30 2020, 02:24 PM
914 Guru Group: Members Posts: 9,040 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The base wheel are all the same. Only difference is the mounting hardware. No part numbers stamped except for the horn contact ring on later model. Used VW contact.
mepstein |
914-6 GT in waiting Group: Members Posts: 19,679 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Any wheel that part number ends in “10” is early, has a flat front and uses a horn push button. The back fits on a Porsche style steering shaft. Wheels that end in “11” are mid and late. They have a bevel on the front. The back fits a VW style shaft. The early horn pads have a flat area for the horn button. The mid and late have a little tab for a horn wire.
dr914@autoatlanta.com |
Jan 30 2020, 02:47 PM
914 Guru Group: Members Posts: 8,113 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
the steering wheels are all the same except for the numbers, for the plastic ones and the leather ones and the foam ones. However the hubs are different
70-71 914-4 with plastic hub 72-76 with shorter plastic hub 70-71 914-6 with no hub 72 914-6 with shorter plastic hub the leather wheels follow |
Tdskip |
Jan 31 2020, 12:13 PM
Thank you gentlemen – sorry for the belated response .
Lo-Fi Version | Time is now: 5th January 2025 - 03:06 AM |
