crash914 |
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,829 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region ![]() |
Since I am building another hot type 4 motor, I had a thought about installing it into a boxter.
Has anyone tried this? Full disclosure, boxter has a blown engine and I will have a fresh 4... |
Chi-town |
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California ![]() |
It would be horribly under powered.
The boxster weighs almost 1000lbs more than a 914 |
crash914 |
not really serious about this...just saw an ad for a very cheap boxter..
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,824 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
^^^^This!
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,786 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
not really serious about this...just saw an ad for a very cheap boxter.. I would install a subi motor or LS in that Boxster. Renegade sells kits to do this. You would certainly surprise some 911's with a built LS engine in a Boxster. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
LS engine is little hard to shoehorn into a boxster, even a 996 is (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif)
If doing an LS I'd start with a 996. Still not cheap and easy, the renegade kit alone will run you $7-9K IIRC. A guy on YT did it for $17K paying a guy $45/hr, used engine, etc. I'd say DIY about $12-13K is the cheapest the project will cost you, still it's way cheaper than a $25K- $40K for a new MY96 engine. A boxster would be still a loser for resale, a 996 might be break even. |
crash914 |
It sounds like even finding a way to repair the existing engine is not going to be cost effective...as resale value would be low anyway.
where is motor meister when you need them! Mark, you don't have a stroker crank hanging around do you? |
Mark Henry |
Yes, an 80mm but it's spoken for, the wife's 914 (IMG:style_emoticons/default/biggrin.gif)
cheapest way to fix a 996 or boxster engine is with a factory shortblock exchange, but then you still have to do the rest of the engine. The 996/boxter flywheel you have to replace, the rubber center goes and causes misfire codes, add a clutch kit and there's a couple grand. Same with the coil packs, around $500 not replacing them is false economy. Big issue is making sure the rads are clean, you have to take the front bumper cover off to see all the crap behind the AC condenser. I just replaced the rads in a 4S with a pair of CSF rads, beautiful units. AOS, water pump, T-stat, starter Y cable...Nothing is cheap, the price creep is large with these cars. Just did a 4S, $5k quote for IMS, by the time all the "while you're in there" stuff was done $15K easy. |
flmont |
Senior Member ![]() ![]() ![]() Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region ![]() ![]() |
why would it be so expensive to put a subaru 4 cylinder turbo in a boxster is it a engine to tranny mating issue or a ECU/wiring issue.?
Chris H. |
If you can fab the one-off stuff you need like the motor mount it wouldn't be too expensive. You can use the stock ECU, or there are many other reasonably priced options. Kennedy could make the engine-trans adapter plate.
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
The Audi motors bolt into the boxster trans FYI...
I want to get a boxster and start playing around (IMG:style_emoticons/default/smile.gif) |
Chris H. |
DO IT! Old Boxsters are SO CHEAP, especially ones with engine issues.
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
The Audi motors bolt into the boxster trans FYI... I want to get a boxster and start playing around (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/agree.gif) I'm looking for a Cayman S (IMG:style_emoticons/default/wub.gif) a Cayman really needs a W8 or W12 in its mid section. |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,260 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Value of a "hot".....whatever that means.... Type 4
10k. Value of a used running 986....6-7k. Yes....that.s crack pipe time. |
jpnovak |
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region ![]() |
The Audi motors bolt into the boxster trans FYI... I want to get a boxster and start playing around (IMG:style_emoticons/default/smile.gif) I have always wanted to adapt the Audi 4.2 Motronic to a Boxster. That should be almost the hardest part getting the 2 extra injectors to play nice. I think this is a perfect match. I still don't know why the RH LS kit is so expensive. |
crash914 |
My hot 4 is around 15k..good thing I can use lots of my parts. Rebuild cost is only around 3k.
914forme |
The Audi motors bolt into the boxster trans FYI... I want to get a boxster and start playing around (IMG:style_emoticons/default/smile.gif) I have always wanted to adapt the Audi 4.2 Motronic to a Boxster. That should be almost the hardest part getting the 2 extra injectors to play nice. I think this is a perfect match. I still don't know why the RH LS kit is so expensive. Because they spent the time and engineering to produce at least part of the kit. Even if you source the bell housing pressure plate else where it was a 2K item. For such low production numbers the kit does not seem outlandish to me. |
Lo-Fi Version | Time is now: 15th March 2025 - 03:10 AM |
