> Blower Motor options, What motor should I be looking for
n2j2ryan
post Feb 7 2020, 10:15 PM
I have a 72, with a 2.0 from a 73 (I think). I am missing all of the heater components inside the engine bay. My question is: Which blower motor should I be looking for?
Mikey914
post Feb 7 2020, 10:45 PM
The rubber man
Single poet, but you can use a dual as an upgrade if you wish. Either will work. It's just a matter of how you plumb it.
n2j2ryan
post Feb 7 2020, 10:48 PM
That's funny. I was just chatting with Matt and he wasn't quite sure so said to post it on here! I need everything from the HE to firewall so as long as I get a package it will work.
914werke
post Feb 7 2020, 11:27 PM
the 72 chassis didnt have the stand welded to the drvrs shelf so the early blower that mounted to the impeller housing is probably called for unless you get one of these
Mikey914
post Feb 8 2020, 12:54 AM
The rubber man
I know some early have the mount on the engine. My 72 has the stand on the drivers side. Not sure where the cut off is. See if you have the stand that looks like the picture. If not I may have one of the early mounts for the fan. I’ll have to check.
GeorgeRud
post Feb 8 2020, 01:49 PM
You might check with 914Ecology to see if Garold has the parts you’re looking for.
n2j2ryan
post Feb 8 2020, 03:47 PM
So I did find this in a box, but no other metal
914werke
post Feb 8 2020, 05:08 PM
(IMG:style_emoticons/default/aktion035.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 05:13 PM
