> Finish on wheels question
dt4
post Feb 9 2020, 04:16 AM
Region Association: England
Morning all
Is there a finish on the wheels that gives the satin or polished finish
I expected it to be either polished or non polished alloy but it appears to have been broken through in places Attached Image Attached Image
bdstone914
post Feb 9 2020, 05:42 AM
bdstone914
They are anodized. The pedals ate polished and the recessed areas satin.
dt4
post Feb 9 2020, 06:34 AM
Thanks, that's good to know
dt4
post Feb 12 2020, 12:59 PM
Thought I would give polishing the petals a goAttached Image
dt4
post Feb 12 2020, 01:00 PM
QUOTE(dt4 @ Feb 12 2020, 06:59 PM) *
TargaToy
post Feb 12 2020, 01:19 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
QUOTE(dt4 @ Feb 12 2020, 01:59 PM) *
That looks nice. What was your procedure?
Will you attempt to seal the "new" fiinish or just stay on top of polishing it?
dt4
post Feb 12 2020, 02:27 PM
I used a 200 grit sanding pad on a 3" airsander to remove the anodising and the scuff marks etc... then went upto 600 then 1000 then 2000 then polished with a mopping pad and autosol metal polish
I had to planish the centre cap to get it reasonably flat first as it was pretty beat up ten sanded it flat before polishing
dt4
post Feb 12 2020, 02:29 PM
I will see how they get on before deciding whether to seal them
jim_hoyland
post Feb 13 2020, 01:32 PM
Get that VIN ?
Nice job; what would seal the surfaces ?
Front yard mechanic
post Feb 13 2020, 02:34 PM
Silver paint goes a long way not to be a Debbie downer (IMG:style_emoticons/default/barf.gif)
dt4
post Feb 15 2020, 01:19 PM
Not a fan then lol
One of the centre caps is pretty beaten up
Mikey914
post Feb 15 2020, 01:27 PM
The rubber man
QUOTE(dt4 @ Feb 12 2020, 12:27 PM) *
When you polish they will be more shinny. I stock the polished and the anodized.
Polishing and making look good take a lot of time. That and dis-similar metals will continue to corrode the OEM caps making them hard to remove
https://900designs-container.zoeysite.com/s...h/?q=center+cap
Make sure to look at the set of 4 as it's cheaper than individuals
dt4
post Feb 16 2020, 12:31 PM
A bit of planishing, sanding and polishing laterAttached Image Attached Image
- Lo-Fi Version Time is now: 27th December 2024 - 02:55 AM
