Getting to Know You...., Geek'n Out on rocker cover removal and inspection |
Craigers17 |
Feb 15 2020, 04:32 PM
Senior Member Group: Members Posts: 809 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
So this is the first decent day that I've had time to put the newly acquired '74 on jack stands and get to know her a little bit. I pulled off the rocker covers, and a tire and took some pics.
The worst rust I found was a brace on each rocker and a fairly massive hole under the driver's side seat/base of the firewall near the air deflector. All of this had been disclosed by the P.O. Also, briefly scanned the underside and got the transaxle and engine numbers. By the way, one of the trailing arms clearly had a "K" stamped on it. Is that a Karmann stamp or does anyone know? |
Craigers17 |
Feb 15 2020, 04:35 PM
Craigers17 |
Feb 15 2020, 04:37 PM
Craigers17 |
Feb 15 2020, 04:40 PM
Craigers17 |
Feb 15 2020, 04:57 PM
Craigers17 |
Feb 15 2020, 05:01 PM
Craigers17 |
Feb 15 2020, 05:03 PM
bkrantz |
Feb 15 2020, 08:52 PM
914 Guru Group: Members Posts: 8,175 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
The jack tube cover flange looks different from original. You might want to investigate what is behind it.
Lo-Fi Version | Time is now: 26th December 2024 - 06:46 PM |
