dwillouby |
Member ![]() ![]() Group: Members Posts: 393 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None ![]() ![]() |
Hello,
Does anyone have experience with the Autometer GPS speedometers? Thinking about installing the speedometer & GPS system as I am running the Boxster S trans behind my LS with no provision for the speedometer. I think this would be the easiest solution. Any tips such as antenna locations? Can the antenna be hidden? reliable readings? Thanks David |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Hello, Does anyone have experience with the Autometer GPS speedometers? Thinking about installing the speedometer & GPS system as I am running the Boxster S trans behind my LS with no provision for the speedometer. I think this would be the easiest solution. Any tips such as antenna locations? Can the antenna be hidden? reliable readings? Thanks David I have a GPS speedo in my big six. The cayman trans doesn't have a speedo output, and I was lucky enough that I already converted to the GPS speedo years ago. I used an Autometer GPS converter box and an electronic 911 Speedometer. Here is a link to the thread that tells the story... http://www.914world.com/bbs2/index.php?showtopic=230296 |
Lo-Fi Version | Time is now: 25th June 2024 - 10:39 PM |
