> Tail shift to side shift, What extra parts do I need
n2j2ryan
post May 10 2020, 06:57 PM
So I have been reading a lot of the posts about converting a tail shift to a side shift, and finally realized that the articles were about actually converting a tail shift to a side shift and getting worried (that should give you an idea of my mechanical prowess). I do have complete linkage from both a tail and side shift transmission. From what I can figure out, besides replacing the bushing all around, the only piece that I would be missing would be a conversion bushing at the firewall? Is that correct? Is there any difference between the actual shifters?
Thanks for any help.
9146C
post May 10 2020, 07:18 PM
http://www.autoatlanta.com/Porsche-Early-T...N-BSLC9144.html
post May 10 2020, 07:19 PM
914-6 GT in waiting
Shifters are different. So are both the small and large shift rods, firewall bushing, cross bar, motor mounts and 2 engine tins under engine.
n2j2ryan
post May 10 2020, 07:29 PM
I am pretty sure that kit is if you want to convert your tail shift to side shift, not for installing a side shift into an early car. Could be wrong.
QUOTE(9146C @ May 10 2020, 06:18 PM) *
n2j2ryan
post May 10 2020, 07:38 PM
Thanks, that was about what I was thinking. I have everything but the firewall bushing so I will get one of those ordered.
QUOTE(mepstein @ May 10 2020, 06:19 PM) *
post May 10 2020, 07:50 PM
914-6 GT in waiting
QUOTE(n2j2ryan @ May 10 2020, 09:38 PM) *
I think what you want is called a conversion bushing, not just the normal bushing for a sideshift car.
914werke
post May 10 2020, 08:26 PM
Neil if LMK if I can help. (IMG:style_emoticons/default/smile.gif)
bdstone914
post May 10 2020, 09:32 PM
bdstone914
@n2j2ryan
Here is a picture of the external parts you need. The shifter is needed.
To convert t hff e trans you need the shift console, internal shift rods and forks. Tail cone is optional. You can plug the tail shift rid hole in the tail cone.
You also need a passenger side warm air guide form a 73-74.
bdstone914
post May 10 2020, 09:38 PM
bdstone914
@mepstein
Only the left warm air guide is different.
bdstone914
post May 12 2020, 10:02 AM
bdstone914
@n2j2ryan
' date='May 10 2020, 05:57 PM' post='2813792']
[/quote]
Here is a picture of the linkage parts needed to convert to a side shift.
The only missing part it the firewall conversion bushing.
bdstone914
post May 12 2020, 10:23 AM
bdstone914
Here are the rear shift cover and bellows needed too.
- Lo-Fi Version Time is now: 26th December 2024 - 04:05 PM
