914ltd |
Member ![]() ![]() Group: Members Posts: 239 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None ![]() ![]() |
After a long dry spell, I am seeing trigger points problems again. I have many sets to test. Rent me yours? Locate the maker? Thanks, Brad Mayeur |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Brad,
Do you a have an old worthless distributor? Just cut it in half so you can mount points. That way you can watch them open and close with a meter. Maybe this will work for you. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,190 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Brad do a search on UID = nordfisch @nordfisch
914ltd |
Brad, Do you a have an old worthless distributor? Just cut it in half so you can mount points. That way you can watch them open and close with a meter. Maybe this will work for you. Hi Mark That's way too simple. I tend to lean toward the complicated, ridiculously expensive solutions and expect poor results. (Thanks!) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:18 AM |
