> I changed the firewall bushing...., ....and wanted to share my experience to help others
Frankvw
post May 17 2020, 11:33 AM
working on my first 914 !
Region Association: Europe
so....firewall shifter bushing replacement !
I followed the how-to of ROb under
http://www.914world.com/specs/fwsb_replace.php
That was of course very helpfull.
I want to show some details and tips&tricks I used to do mine
Mine is a 1973 1.7. That is important, because there are several version (and sizes) around for this part.
Early, Late, conversion, specials like Tangerine or Rix etc.
I did not have a bushing in the firewall (I thought) and the rod was rattling and the shift play was huge.
I took it apart and found the old bushing in pieces in the rubber boot and a piece in the tunnel.
So ...I asked the 914 parts guy in the Netherlands for the bushing, but he had only a full set, and I needed only the firewall bushing since the others were in great shape and maybe even replaced in its life sometime
Guess what, they are easy to order from Porsche ! I ordered and two days later they mailed it arrived from Germany and I picked it up.
You can see the differences between the original Porsche part and the aftermarket part, no idea what brand or manufacturer that is.
But you will find out there are different versions the moment the wrong one does not fit or has too much slop.
The quality of the original part is way better and the size/dimensions are looking good !
You also need the two new conescrews, pictured as well, since the old ones cannot be reused, they have a locking mechanism that is a one-time use.
I was lucky the old conescrews came out easy, probably because in the past someone already looked at the other bushings.
When I followed the how-to, it is mentioned:
"pull the gear shifter into 3rd, to separate the two sections of the rod....
This should pull the front section out of the firewall and into the center tunnel
But not on my 73 car. I had to unbolt the shifter to get the rod in the tunnel.
But before I dropped it into the tunnel, I did this:
a piece of electrical copperwire, bend it, the bend part in the conescrew hole, ducktape is your friend to hold it..
and then dropped the rod in the tunnel.....and replaced the bushing.
Ok, here I have to be honest. I knew for sure that I did not need to boil it, because I am Dutch and we are smart-asses and are the best. Who needs boiling !??
Ok, I have to admit that it is better to listen to the American guy in the how-to in this case. Just boil it, it was super easy after boiling !
Installed it and then looked like:
After that just pull the wire and get the rod back through the bushing.
So...no need to call the wife to ask her to select a gear. She will not listen properly, it is another shiftpattern in her own car and you will get a fight.
She is also Dutch, remember , so she is also a smartass and the best.
So, one man, one hand job, no wife. hey... oh ..never mind.
And no fishing is the tunnel for the shiftrod trying to get it through the new bushing !
Remove wire and I have my bushing in place.
To re-install that rubberboot I was fiddling for a long time. Then I started by hand on top and side and used a pick on lowest part and took me 10 secs.
Car is still on jackstands for other work, so no testdrive yet, but I come from no-bushing, and the rod is already tight in there with that new part !
I know it will be an improvement !
Hope this can help as add-on on the already how-to there is !
Again...I will use the banana now....I think I earned it (IMG:style_emoticons/default/piratenanner.gif)
falcor75
post May 17 2020, 11:57 AM
If you look between the seats there is an access panel held in with one screw that lets you easily access the shift rod and push it thru the hole if needed.
You know for next time you do this.... (IMG:style_emoticons/default/smile.gif)
Frankvw
post May 17 2020, 12:02 PM
QUOTE(falcor75 @ May 17 2020, 11:57 AM) *
I know, I had it open. But this was my trick since I was alone and did not want to ask my wife to help me (IMG:style_emoticons/default/smile.gif)
jmalone
post May 17 2020, 12:33 PM
QUOTE(Frankvw @ May 17 2020, 11:02 AM) *
Excellent and entertaining post! (IMG:style_emoticons/default/bye1.gif)
depair
post Sep 29 2024, 06:47 AM
FANTASTIC! THANKS!!!
StarBear
post Sep 29 2024, 07:01 AM
Smooth operator. (IMG:style_emoticons/default/biggrin.gif) Thanks for sharing.
DennisV
post Sep 29 2024, 07:44 AM
QUOTE(Frankvw @ May 17 2020, 10:33 AM) *
Humorous and helpful post. Thanks for sharing Frank. I'll be trying this one person approach in the coming months.
You're the best! (IMG:style_emoticons/default/biggrin.gif)
brant
post Sep 29 2024, 10:01 AM
It’s really recommended to change all of the bushings unless you have proof/knowledge of when they were last changed
The shift console bushing also highly impacts shifter accuracy
As much as the firewall
You’ve got the hardest one and should also change the easy ones
Porschef
post Sep 29 2024, 03:43 PM
How you doin'
If you want to get the best out of the situation, get a Tangerine firewall bushing. Will last the duration of your car, and removes as much slop as possible in that spot. Pretty easy installation. Renewing all the other bits downstream of it will add to a much better shifting experience (IMG:style_emoticons/default/beerchug.gif)
And as Brant mentioned, the console bushing is just as important, even the brass ones can have some slop (although they’ll last longer). I made one from Delrin years ago, still doing fine.
brant
post Sep 29 2024, 04:08 PM
QUOTE(Porschef @ Sep 29 2024, 03:43 PM) *
What I ended up doing for the console bushing
JamesM
post Sep 29 2024, 05:19 PM
QUOTE(brant @ Sep 29 2024, 02:08 PM) *
I resisted this mod for years as I tend to avoid irreversible changes, but then I realized I had 5 spare shift consoles/trannies so I finally but the bullet... Totally worth it along with a spherical firewall bushing. Top it off with a Renshifter and its like driving a totally different car.
jbyron
post Sep 30 2024, 09:39 AM
Jamie
Your post is inspiring me to do my own bushings. thanks!
- Lo-Fi Version Time is now: 16th January 2025 - 01:11 PM
