Horn Slip Ring - no longer in stock, Compatibility with other VW or Porsche rings? |
frostyf |
May 19 2020, 11:57 AM
Member Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Hi, wondered if anyone knows about compatibility for the different horn cancellation rings.
I think mine needs changing - looked up the part on the OEM diagrams and its listed as : # 91434709900 Couldn't see them available any more on Pelican or AA. AA have an alternate numbered part # 113415660A and their page says Fitment: 924 76-85 944 82-85. Does anyone know if this matches the VW part #113415660A which fits: Type 3 (Squareback/Fastback); 1971-1979 Karmann Ghia; 1971-1974 Type 4 (411/412) 1971-1974 Has anyone fitted one of these newer replacement slip rings and did it fit okay to a 914? Thanks in advance! |
Bleyseng |
May 19 2020, 01:07 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Jamie |
May 19 2020, 01:12 PM
Senior Member Group: Members Posts: 1,077 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Hi, wondered if anyone knows about compatibility for the different horn cancellation rings. I think mine needs changing - looked up the part on the OEM diagrams and its listed as : # 91434709900 Couldn't see them available any more on Pelican or AA. AA have an alternate numbered part # 113415660A and their page says Fitment: 924 76-85 944 82-85. Does anyone know if this matches the VW part #113415660A which fits: Type 3 (Squareback/Fastback); 1971-1979 Karmann Ghia; 1971-1974 Type 4 (411/412) 1971-1974 Has anyone fitted one of these newer replacement slip rings and did it fit okay to a 914? Thanks in advance! A general question about VW/914 parts compatibility. I recently was looking through a JBugs catalog that was included with my wheel spacers, and there are several parts listed for 914/VW applications. Do any of you know whether some general parts like switches, etc. might be the same as the Porsche OEM equivalents? |
914e |
May 19 2020, 02:47 PM
Member Group: Members Posts: 497 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
I used 113 415 600 A
however the part molded into the part is 111 415 662 Buy a genuine Porsche part, the aftermarket versions are so poorly molded the part is warped. |
frostyf |
May 19 2020, 07:36 PM
Yep that's the one, but will it fit a 914? |
HansJan |
May 19 2020, 07:43 PM
Member Group: Members Posts: 399 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
I used 113 415 600 A however the part molded into the part is 111 415 662 Buy a genuine Porsche part, the aftermarket versions are so poorly molded the part is warped. (IMG:style_emoticons/default/agree.gif) |
frostyf |
May 20 2020, 06:16 AM
I used 113 415 600 A however the part molded into the part is 111 415 662 Buy a genuine Porsche part, the aftermarket versions are so poorly molded the part is warped. (IMG:style_emoticons/default/agree.gif) For anyone hunting for one of these, I found what I think might be an original at Sierra Madre Collection - at least it has the original and not the replacement part number? |
Steve |
May 20 2020, 08:15 AM
914 Guru Group: Members Posts: 5,771 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I used 113 415 600 A however the part molded into the part is 111 415 662 Buy a genuine Porsche part, the aftermarket versions are so poorly molded the part is warped. (IMG:style_emoticons/default/agree.gif) For anyone hunting for one of these, I found what I think might be an original at Sierra Madre Collection - at least it has the original and not the replacement part number? I bought two of the Sierra madre 914 part number horn rings. They fit perfect on my stock 1975 steering wheel. No modifications at all, however I’ve always had problems with horn rings on my Momo hub. The hole for the horn wire is too far to the side, so I have to dremel away some of the plastic to get the ring to lay flat and line up with the holes. |
Lo-Fi Version | Time is now: 4th January 2025 - 09:33 PM |
