Powered subwoofer - Pioneer TS-WX130DA, Has anyone installed/tried one of these? |
drem914 |
May 24 2020, 12:57 PM
Senior Member Group: Members Posts: 1,051 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Very compact, 11x8x3. Would fits in place of foam footwell piece. Has anyone installed one of thse in the 914? Not a lot of wattage, so not a lot of punch, but also not lot of draw (4+ Amps.) Any one used one of these Pioneer compact powered subs?
https://www.crutchfield.com/p_130TSWX130/Pi...0DA.html?tp=114 |
tvdinnerbythepool |
May 24 2020, 01:13 PM
Member Group: Members Posts: 310 Joined: 24-July 18 From: Olympia, WA Member No.: 22,336 Region Association: Pacific Northwest |
Very compact, 11x8x3. Would fits in place of foam footwell piece. Has anyone installed one of thse in the 914? Not a lot of wattage, so not a lot of punch, but also not lot of draw (4+ Amps.) Any one used one of these Pioneer compact powered subs? https://www.crutchfield.com/p_130TSWX130/Pi...0DA.html?tp=114 This is crazy!! Literally this morning I was looking at this for my 914 and was wondering the exact same thing! |
Mark Henry |
May 24 2020, 01:29 PM
Likely better than nothing, but not as good as an amp and an 8+" sub.
50 watts I doubt if you would hear it much over the engine. |
drem914 |
May 24 2020, 01:36 PM
Likely better than nothing, but not as good as an amp and an 8+" sub. 50 watts I doubt if you would hear it much over the engine. Yes but at that point I dont care anymore. (IMG:style_emoticons/default/driving.gif) The draw is very low. There is another from Kenwood that is about the same size but it's peak draw is 7 amps with 75 watts RMS. just looking for a simple install. |
911GT2 |
May 24 2020, 02:14 PM
Member Group: Members Posts: 195 Joined: 2-March 11 From: The Netherlands Member No.: 12,773 Region Association: Europe |
I have the bigger brother in my Westy the TS-WX 210A and I must say, I love it. The sound is more than adequate. So I think in a small car the 130 will suffice.
Garland |
May 24 2020, 02:24 PM
Restoration Fanatic Group: Members Posts: 1,400 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
Garland |
May 24 2020, 02:25 PM
Error
horizontally-opposed |
May 24 2020, 03:14 PM
Advanced Member Group: Members Posts: 3,453 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Genius. Love the integration shown in your build thread. Question: Did you lose any leg room? Hard to tell from the angles. Have an amp that's set up to run a woofer, which makes me wonder if I can find something similar to your sub but without the self-supplied power. |
Garland |
May 25 2020, 10:07 AM
Loss of About 2 inches On leg room, my wife still requires the foot stool to Be able to reach, and brace her feet against the foot well. I used the integrated amp style finding it produced better base in most cases than a homemade box and separate amp.
IronHillRestorations |
May 25 2020, 10:16 AM
I. I. R. C. Group: Members Posts: 6,795 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
50 watts with the right driver in the right cabinet can be just as effective as 100 watts with the wrong driver in a janky cabinet
drem914 |
Jul 4 2020, 06:27 PM
Well, went with the Kenwood unit. Connected straight up to my existing Blaupunkt head unit. Everything fits behind the bulkhead carpet. So far I just pulled the old foam plug. I still need to clean up the speaker wires a little more before heading out on a driving test
It certainly fills out the sound from the Polk DB652's in the 914Rubber kick panels. (IMG:style_emoticons/default/aktion035.gif) Will try to post photos once all the wires are cleaned up. |
RickS |
Jul 4 2020, 09:30 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I’ve had two of them and they work really well. Not like an amp powered 8” but good enough to rattle the sheet metal without distortion. May buy another for my current 914.
drem914 |
Jul 4 2020, 10:29 PM
I’ve had two of them and they work really well. Not like an amp powered 8” but good enough to rattle the sheet metal without distortion. May buy another for my current 914. |
sfrenck |
Jul 5 2020, 05:32 AM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
I went with a Kenwood KSC-SW11 unit (looks close to the one you show) hung upside-down under the dash (under the heater controls).
More than enough bass, no lost legroom. |
FlacaProductions |
Jul 5 2020, 10:28 AM
Senior Member Group: Members Posts: 1,863 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
@sfrenck - interesting approach - any chance of a pic or two?!
sfrenck |
Jul 7 2020, 05:22 PM
drem914 |
Jul 7 2020, 05:56 PM
Pics of installation under the radio/right of the fan comtrols.. As I am still planning on putting the original center console back in I went the route of going under the front bulkhead carpet |
CCE |
Feb 16 2023, 10:22 PM
CCE Group: Members Posts: 328 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
How does this work for the passenger feet? Do they hit it? I Can see in my car the photo you show was in an angle that is not really natural to see, I think it can be very discrete… I like the solution, very much. Just wondering about the passenger feet. Please your comments.. here is a picture of mine. |
Lo-Fi Version | Time is now: 15th January 2025 - 06:59 AM |
