Can broken door pull be welded? |
Tdskip |
Aug 13 2020, 12:11 PM
Advanced Member Group: Members Posts: 3,702 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Superhawk996 |
Aug 13 2020, 12:18 PM
914 Guru Group: Members Posts: 6,502 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
@Tdskip
My experince is that Zinc based pot metal cannot be welded. Aladdin 3 in 1 rod is my go to solution. Not really welding more like soldering or brazing. http://sourcewelding.com/index.php?main_pa...&cPath=8_80 However, the heat required will damage the chrome and the heat tends to move things around dimensionally. Technically feasible - yes. Financially viable - not really. You will be better off to just find a nice used replacement. I have a few pictures of a zinc pot metal based tractor part I repaired recently over on my build thread if you're interested (page 17). After the brazing, I had to remachine the part substantially to get it back to useful condition and I'm still not convinced of the strength of the repair. |
914Sixer |
Aug 13 2020, 12:24 PM
914 Guru Group: Members Posts: 9,005 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Buy new door flap reproduction from AA. $25 + shipping on Ebay
mepstein |
Aug 13 2020, 12:32 PM
914-6 GT in waiting Group: Members Posts: 19,578 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Rand |
Aug 13 2020, 12:38 PM
Yeah, you can't weld pot metal. But if URY is still around??? he used to have repair options. Too bad somebody doesn't make a quality replacement. I guess milling a billet version isn't cost effective.
Serves as a PSA I guess, don't yank on them. That's how they break. If you put your thumb at the pivot point and just rock the handle to release it will last a lot longer. Kind of like how you don't just pull the engine lid release and let it slam open...Put your hand on it. Take care of these fragile bits! (IMG:style_emoticons/default/smile.gif) |
roblav1 |
Aug 13 2020, 12:39 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Odds of successful weld on that is pretty slim.
Rand |
Aug 13 2020, 12:43 PM
Tdskip |
Aug 13 2020, 12:55 PM
Thanks for all of the responses, will track down an un-damaged replacement (or three).
Have a good day gentlemen! |
dr914@autoatlanta.com |
Aug 13 2020, 01:02 PM
914 Guru Group: Members Posts: 8,092 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
no way pot metal, but new repro door latches are very cheap these days. We used to make a replacement flap but are out of them, we do have the replacement bases though if you would ever need one of those
URY914 |
Aug 14 2020, 04:26 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,652 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That break can't be fixed. |
Tdskip |
Aug 14 2020, 05:57 AM
Thanks, I will bin it.
What, if anything, should be saved from it? The tan plastic piece has a small crack/tear in it so that is scrap as well I assume. |
Superhawk996 |
Aug 14 2020, 06:07 AM
Thanks, I will bin it. What, if anything, should be saved from it? The tan plastic piece has a small crack/tear in it so that is scrap as well I assume. Can drill rivit and keep the base as spare for yourself or someone that has the dreaded stud failure on the base. (IMG:style_emoticons/default/happy11.gif) If the tan plastic slide is cracked pitch it. That is where the often break first even if you are using proper technique as previously noted to use thumb at the pivot and don't yank on the flap directly. Lock cylinder core, wafers, and springs are also useful to some. |
Tdskip |
Aug 14 2020, 06:14 AM
Thanks, hope it’s been a good week so far.
Lo-Fi Version | Time is now: 31st October 2024 - 07:23 PM |
