New Fuel Line suggestions, Expert opinions needed for safety. |
ri914 |
Aug 31 2020, 06:26 PM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Ok, got the gas tank out last night.
Going to run 2 new steel lines. My plan was to use 3/8 for both lines and place a small low pressure pump under the tank to feed the 60psi pump back near the LS motor. Is it safe to run all low pressure fuel hoses and connections to and from the tank? I was planning on using 6AN connections for the high pressure line from the big pump to the motor? thoughts and suggestions are greatly appreciated. thank you Attached thumbnail(s) |
ndfrigi |
Aug 31 2020, 07:36 PM
Advanced Member Group: Members Posts: 2,960 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
stock 914 FI fuel pump for 28 to 31 psi are doing his job and even for carbs with 2.5 to 3psi does not have any problem.
ooops edit: You are referring to fuel hoses. I believed everytime you have FI system, you really need to use high pressure fuel hoses for all lines. |
porschetub |
Aug 31 2020, 08:59 PM
Advanced Member Group: Members Posts: 4,761 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Don't piss around ,put the best you can find on LP and HP hose,and on FI hoses you need right clamps ,FI ones are the only way to go,think safety (IMG:style_emoticons/default/smile.gif) .
Good luck. |
ChrisFoley |
Sep 1 2020, 08:52 AM
I am Tangerine Racing Group: Members Posts: 7,969 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page |
tygaboy |
Sep 1 2020, 09:00 AM
914 Guru Group: Members Posts: 5,477 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page (IMG:style_emoticons/default/agree.gif) What @ChrisFoley said! Save yourself time, buy the Tangerine Racing stuff and sleep well knowing you have a safe and high quality fuel line set up. |
ClayPerrine |
Sep 1 2020, 09:51 AM
Life's been good to me so far..... Group: Admin Posts: 15,965 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page (IMG:style_emoticons/default/agree.gif) What @ChrisFoley said! Save yourself time, buy the Tangerine Racing stuff and sleep well knowing you have a safe and high quality fuel line set up. (IMG:style_emoticons/default/agree.gif) Don't let an engine fire from using cheap fuel hose ruin your 914. |
ri914 |
Sep 1 2020, 03:57 PM
wow, well it looks like I have a solid game plan now (IMG:style_emoticons/default/smile.gif) going to call my local vendor and purchase some lines.
thank you all (IMG:style_emoticons/default/smile.gif) |
Matty900 |
Sep 1 2020, 04:35 PM
Senior Member Group: Members Posts: 1,284 Joined: 21-February 15 From: Oregon Member No.: 18,454 Region Association: Pacific Northwest |
I am about to do the same for my LS swap. I will be using the stainless steel lines in the tunnel that are available from existing vendors like Chris. I will be connecting it all together with custom lines from Dyme. Pretty awesome stuff. https://dymepsi.com/product/hose-builder/
cary |
Sep 1 2020, 10:08 PM
... Going to run 2 new steel lines. ... Is it safe to run all low pressure fuel hoses and connections to and from the tank? ... Consider using pre-bent stainless lines (made by a nearby vendor) in the tunnel. Use Gates Barricade (or similar) high pressure hose, even in the low pressure parts of the system. Tangerine Racing Fuel System Page Near By Vendor, too funny. |
ChrisFoley |
Sep 2 2020, 03:40 PM
Near By Vendor, too funny. Close enough that he can come here to pick them up if he wants. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 06:23 PM |
