> SOLVED - Parts Left over - Oil Cooler - part num: 039117187, IN the 2.0 there is this thing - cannot find where to put it!
ctc911ctc
post Sep 5 2020, 05:06 PM
'74 2.0 stock
I have the engine back together and there is this part (num: 039117187) left over.....UGH -- PART # 5
Can I get this part installed with the fan shroud on? If the part is NOT installed what will happen?????
I took the engine out to fix oil leaks - I am not giving up, I will strip the entire thing down again (GULP) if this part will protect me from leaks!
Can someone show a picture as to where it goes?????
Thank you,
davep
post Sep 5 2020, 05:50 PM
914 Historian
The outside bracket has a welded arm on the top. This loose piece goes at the bottom and further braces the oil cooler. Only installed on the 2.0 engines that I know of.
ctc911ctc
post Sep 5 2020, 07:43 PM
After writing this I figured it out - here is a map of the parts installation
And the part installed - had to bend the tin a bit to get it in place.
- Lo-Fi Version Time is now: 4th January 2025 - 09:10 PM
