> Proper Torsion bar install and adjustment, how to install and adjust the torsion bars on the front suspension
ri914
post Sep 20 2020, 10:00 AM
Hello 914'ers
I need to adjust and calibrate my front suspension. I installed the new torsion bars while the car was on the lift and it now looks like it could chase a ford raptor through the woods.
1: Is there a procedure for installing these and what angle the a-arm should be at?
2: Should they be done at ride height and then adjusted by the torsion bar adjustment bolt ?
thank you
ben
brant
post Sep 20 2020, 10:39 AM
Index them to get the range of ride height you want
Then fine tune on corner balance scales
914Sixer
post Sep 20 2020, 11:20 AM
Bars have to be indexed before installation. Most repair manuals should cover this. Adjusters are just used for minor up or down of 10-20 mm.
jim_hoyland
post Sep 20 2020, 11:38 AM
Get that VIN ?
How does the indexing go if the caris up on the lift ?
rhodyguy
post Sep 20 2020, 12:52 PM
Look at the camber of the rear wheel. Roll your car back and forth a bit to settle the suspension.
mlindner
post Sep 20 2020, 01:52 PM
Ri914, your pictures shows how far off it is. With car weight on suspension that front A-arm should be horizontal as a good start point. If you have purchased stiffer bars you might need to index them on the lift raising the front suspension with like a transmission jack before torsion bar is set. Mark
ri914
post Sep 20 2020, 08:45 PM
QUOTE(mlindner @ Sep 20 2020, 03:52 PM) *
Great info everyone!
Mark. Thanks for the explanation. I knew they had to be way off. Fingers crossed I don't have to roll the fenders.
- Lo-Fi Version Time is now: 15th January 2025 - 01:14 AM
