> Confirming Fuel Line routing, Fuel lines 1974 2.0
simonjb
post Sep 26 2020, 11:03 AM
KiwiMan
Hi,
I just want to confirm my fuel lines as I have now converted to a 2 port fuel pump from a 3 as I rebuild my original 2.0 Djet system. The diagram below and others seem to confirm...
Tank to Filter to Pump to Fuel Rail (Cylinder 3&4) to second Fuel Rail (cylinder 1&2) to Pressure Regulator to Return Tank line. Then a separate line off the (cylinder 1&2) Fuel Rail to the CSV. Correct?
iankarr
post Sep 26 2020, 01:12 PM
Yep. Only difference between 3 port and 2 port is with 2 port the return line from the fuel pressure regulator goes right to the tank return, instead of the pump port.
simonjb
post Sep 26 2020, 01:56 PM
KiwiMan
QUOTE(iankarr @ Sep 26 2020, 01:12 PM) *
Thanks Ian
- Lo-Fi Version Time is now: 26th November 2024 - 02:25 AM
