Making the a-arms "wider"...besides camber issues,, what other "gotchas" will I hit?? |
Mueller |
Jul 13 2005, 08:24 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
Trying to figure out if I can safely go 1" per side to make the front track the same as the rear....I currently have 1.25" thick spacers, so I could eliminate those which would be nice.
I figure not that big of a deal on the camber since that is easily fixed by opening up the top of the shock tower (salvage title car, so no worries about "ruining it" (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) For those that have installed turbo-tie rods, do you think there is enough adjustment to move the ends out an inch per side??? Attached image(s) |
TimT |
Jul 13 2005, 08:37 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
hehehe,
some of "F troop" try and make the A-arm wider offset ball joints etc |
bondo |
Jul 13 2005, 08:39 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Here's a gotcha.. different (lower) effective spring rate!
Mueller |
how much extra "width" does those buy me? |
Mueller |
Jul 13 2005, 08:40 PM
i thought of that one already, just didn't post it...thanks for the reminder (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
bondo |
Jul 13 2005, 08:44 PM
What if you widened the crossmember and moved the front A-arm mounts? Oooh, just widen the whole car! Good luck finding a wider windshield though. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
MattR |
Jul 13 2005, 08:47 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
wider is better (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
could you construct suspension out of steel tubes and eliminate the torsion bar in favor of a coilover? Then you could set any width and geometry you wanted. Keep the original pickup points on the suspension and attach them to the ball joint lower half and a provision for a sway bar. Maybe use spherical bearings at the pickups also? Just a thought. |
Mueller |
Jul 13 2005, 08:48 PM
the wider a-arms would be better....in fact shortening the crossmember a few inches would be best so that the a-arms could be even wider, but I don't think there is enough room for the a-arms to travel up unless major cutting and mods are done to the tub..... |
Downunderman |
Jul 13 2005, 09:42 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Mike,
You can certainly 19mm without any problems, maybe a little more. |
Brett W |
Jul 13 2005, 09:48 PM
Advanced Member Group: Members Posts: 2,858 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
When you lengthen the arms you need to make sure that the inner pivot point does not change in relation to the inner pivot point of the tie rod. THis will mess up your caster and bump steer.
john rogers |
Jul 13 2005, 10:32 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
I use 1 inch spacers in the front and 1 1/4 spacers in the rear and so far have had no issues. Of course the car does get a substantial amount of eye balling since it does get driven pretty hard at times!! I'd say keep the spacers.
Britain Smith |
Jul 13 2005, 10:44 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
There is a guy on the Pelican board that had this done on his car. His name is Jack Olsen and the car is BB2. He is a moderator over there and I bet he could give you some insight.
-Britain |
McMark |
Jul 14 2005, 01:08 AM
I want my car back. You're disrespecting it. (IMG:http://www.914world.com/bbs2/html/emoticons/tongue.gif) |
ArtechnikA |
Jul 14 2005, 06:21 AM
of course. the factory did with the 935's more than 25 years ago, and new 935-style parts are in current production. you do need to reinforce the upper structure some, since it was not designed to accept spring loads. |
redshift |
Jul 14 2005, 06:27 AM
Jack Olsen is the John Peterson of the 911 world. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Damn evil cars! M |
TimT |
Jul 14 2005, 08:40 AM
I think the offset balljoints give you about 3/4 in extra width, but they aint cheap
then you could always do this Attached image(s) |
Mueller |
Mar 28 2006, 12:32 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/icon_bump.gif) for JP (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
so sitting in traffic I got to thinking again about this..... it looks like there is room inside the shock/strut well to cut and move the mounting over 1" or more depending how far you widen the a-arms.... Attached image(s) |
Mueller |
Mar 28 2006, 12:35 PM
the second modification to the steering rack will be just as "fun" to perform (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
you'd need a "sacrificial" rack so that the ends can be cut off, machined and installed to a good rack....this will cure the problem of the turbo tie rods being too short.... Attached image(s) |
turbo914v8 |
Mar 28 2006, 12:39 PM
Member Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 |
groot |
Mar 28 2006, 12:43 PM
Dis member Group: Members Posts: 897 Joined: 17-December 03 From: Michigan Member No.: 1,444 |
Wider is better, as you know. I've done it (by moving the lower control arm mounts inboard and replacing them with tubes and rod ends). My overall stance is a bit wider in the front, but with the coil-overs I have to run a spacer to keep clearance between my spring and tire.
The down side of my setup (as Brett mentioned) is toe out in bump (not sure about caster???), but the upside is good roll center control (very little migration over the range of travel and roll). You can lengthen the tie rods to accomodate... why would you mess with the rack? |
Lo-Fi Version | Time is now: 4th January 2025 - 10:46 PM |
