engine room rubber seal install, any tips to make this easier? |
ottox914 |
Jul 13 2005, 08:53 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Have a full set of seals for the engine tin to body joint. Mine have been slowly coming appart, and have recently gone down hill at an alarming rate. Time to install the new ones. Engine is still in the car. Any tips/tricks to make this easier?
john rogers |
Jul 13 2005, 09:03 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
When I did mine and my daughter's cars I did the following:
- Removed the old rubber and cleaned the channel very well. - Made sure the channel was smooth and straight. - Made a helper tool from a small screwdriver and bent the tip slightly so it could work the seals in - Did the front first as it was the worst. - Lubed the hell out of the rubber and the channel with spray lube - Took frequent breaks so as not to get frustrated - Wished I had a lift as it would be MUCH EASIER then laying on my back in the driveway. |
ottox914 |
Jul 13 2005, 09:05 PM
did you just lay the seal out where it was going to fit, and push it in along its length, or do they slide in a channel from one end and you have to pull/push then thru to the other end? I hate to ask, but how many hours/days did this take? Would heating the rubber in hot water or with a hair dryer help?
MattR |
Jul 13 2005, 09:06 PM
Advanced Member Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California |
Im pretty sure you'll save time if you drop the engine... I cant imagine this being even possible with the engine in there.
tat2dphreak |
Jul 13 2005, 09:30 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) I just did it this weekend... and would have liked more room even WITHOUT the engine in... the side seals weren't bad... front one was a PITA... front an back I did this... I use needle-nose pliers and opened things up a bit, they slid right in, then I went back with big piers and closed the channel down... once I figured out that trick... NO sweat! (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) WD-40 didn't hurt matters either... |
Lo-Fi Version | Time is now: 26th December 2024 - 08:50 AM |
