Oliver |
Member ![]() ![]() Group: Members Posts: 66 Joined: 7-May 05 From: Portland, Or Member No.: 4,038 ![]() |
Hi the car is mostly there but, wher should I start first so I can drive it or is it a lost cause and chop it up? (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
Attached image(s) ![]() |
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) Gonna need a little more info. How are the floors? The rear trunk, under the battery, longitudinals, engine? Pics of these areas would be even better (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Oliver |
I'll post some more pic's I just got a dig camara (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Ft brakes are stuck and brake pedal is stuck to the floor. Re do brakes? What does that cost any way? (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) Fuel pump out redo fuel system (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) What next (IMG:http://www.914world.com/bbs2/html/emoticons/chowtime.gif) Attached image(s) ![]() |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
A fast car is only as good as it's brakes, replace the fuel pump, they are cheap and then try to get it running. When you do the brakes, check all your wheel bearings and shocks. Also check your ball joints and tie rods, make sure the car is safe to drive before ripping up the curves.
GWN7 |
King of Road Trips ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region ![]() |
Looks good so far.
From what I can see the hell hole looks ok. Next look at the longs. Just because she's not a shiny penny dosen't mean it's not a great car. Brakes? Look for a leaky wheel cyl or leakage around the Master cyl. Yep dump the old fuel and replace the fuel line are a must do on every project. |
Oliver |
I would like to get it to the point where it was race safe... (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif)
here coes the pics.. trunk Attached image(s) ![]() |
Gary# |
Member ![]() ![]() Group: Members Posts: 217 Joined: 15-May 05 From: Buena Park, Ca. Member No.: 4,078 ![]() |
Look for rust in all the usual places. Check the hell hole & the passenger side suspension console really really well. Get your BIGGEST buddy to sit in the car with the top off. Close the door. Check both sides. If all's well - it's a keeper.
Everything else is just time and $$$ & more time & more $$$. Please don't chop it up - unless you want the purchase price of these 'lil beauties to go UP-UP-UP. From the pic it looks like a perfect example of a well maintained "east coast" driver. (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Oliver |
the bad spot.... only on the surface?
GWN7 |
hard to tell...take a pic over the spot close up....
Oliver |
Well I'am 260'ish and the door close fine. I like my camara...
Oliver |
. Ok I'll get a close up just a sec...
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
Not looking too bad so far (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
there are quite a few members in the pland area. i'm sure they will be glad to help you acess your car's high spots and problems areas. or at least low ball you on an offer. just kidding. redo your post as a "newbie in portland needs some pointers". seriously. welcome to 914world.com and say goodbye to the low visa balance. again, seriously.
k |
Oliver |
So is it better to start with the brakes? the back ones seemed fine the ft have stuck pistions better to do the whole thing at onice? (IMG:http://www.914world.com/bbs2/html/emoticons/type.gif)
Oh, any advice on brakes will be (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) I live in the portland area and craig for camp 914 has a guy in seattle to rebuild the brakes I dont know the price yet. Hey does any one know the price for some one to rebuild all the brakes? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Attached image(s) ![]() |
GWN7 |
Looks like some pinholes.....
Lou W |
Check the Resource section for Eric Shea |
Oliver |
Is this bad? (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
Thank for the tips... Attached image(s) ![]() |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
From what can be seen so far in your pictures, it does'nt look too bad. Your battery is still where it should be. Pull the rocker panels and look underneath.
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
way WAY better than mine and i drive mine everyday.
Lo-Fi Version | Time is now: 27th June 2024 - 08:06 AM |
