Rebuilt 1700 CC long block, $1000 |
Al Meredith |
Jan 9 2021, 02:12 PM
Senior Member Group: Members Posts: 963 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I am about to start a 2056 and need to sell a rebuilt 1700 that is on my engine run-up stand. The pictures shows it with tin, shroud and 32/36 carb, which I would like to keep because I only use these items for run-up and test purposes . This would be a great for a substitute engine while you rebuild your own . I can arrange to help with delivery within a coulpe hundred miles of Atlanta .
B2524 |
Jan 9 2021, 03:19 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
What new parts were used in the rebuild?
Robarabian |
Jan 9 2021, 10:48 PM
914 A Roo Group: Members Posts: 593 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
bump @mm1
Al Meredith |
Jan 11 2021, 10:13 AM
What new parts were used in the rebuild? New mains and rods , new rings ,new oil seals and gaskets. The valves were lapped and the exhaust ports were opened up , I do this to 1.7 heads because the exhaust ports don't open up to the gaskets. I do balance the pistons and the rods and on this engine I did not install the "head caskets" . If you are interested I have a direct reading oil pressure gauge installed so I can tell you the pressures and I can do a pressure test on the cylinders as well. As I remember the oil pressure was 40 PSI while cranking without plugs . AL |
Al Meredith |
Jan 11 2021, 10:14 AM
[quote name='B2524' post='2881625' date='Jan 9 2021, 02:19 PM']
What new parts were used in the rebuild? [/quote Let me add that the engine is on my run-up stand and has been run about every other month and has no leaks . |
Pops71Por |
Jan 11 2021, 05:49 PM
Newbie Group: Members Posts: 15 Joined: 30-December 20 From: NC Member No.: 25,032 Region Association: South East States |
[quote name='Al Meredith' date='Jan 11 2021, 11:14 AM' post='2882045']
[quote name='B2524' post='2881625' date='Jan 9 2021, 02:19 PM'] What new parts were used in the rebuild? [/quote Let me add that the engine is on my run-up stand and has been run about every other month and has no leaks . [/quote] What is the case #, |
Lo-Fi Version | Time is now: 26th June 2024 - 04:25 AM |
