JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
022905205F
Includes: Trigger points test good 831 vac can, tests good in both advance and retard Advance plate, with copper braid intact Cap and rotor, with visible little wear Whoever wants this please send me your zip code for shipping cost and I'll PM my paypal to you for payment Attached image(s) ![]() ![]() ![]() |
JeffBowlsby |
This complete dizz assembly is factory correct for a Jan 71-1972 1.7L
It has the correct vacuum advance for the distributor, marked 831 on the advance lever arm, which is the abbreviation for PN 1237121831. The vacuum advance hold vacuum, for both advance and retard, and does not leak. I figure the trigger points, vac can and advance plate are worth at least $30 each if I were to separate, so the dizz body/cap/rotor are free. Really want to keep this intact for a deserving 71-72 914 owner. |
JeffBowlsby |
Ok lets make this more interesting.
$75. + shipping or I part it out. |
potomacmidget |
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 161 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States ![]() ![]() |
JeffBowlsby |
Lo-Fi Version | Time is now: 26th June 2024 - 05:15 AM |
