jmz |
Member ![]() ![]() Group: Members Posts: 165 Joined: 11-April 16 From: Lone Star State Member No.: 19,886 Region Association: None ![]() |
what say you? Will I be able to race this and not knock it off and trip over the new front spoiler?
![]() Attached image(s) ![]() |
BillJ |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,273 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None ![]() ![]() |
couple things that would be helpful here is exactly how much clearance each side and center then what suspension are you running. Would mainly be concerned about body roll and dive under braking conditions (full brake). How stiff is the car? Only then can someone (not me) do the math to determine if it is too low.
jmz |
couple things that would be helpful here is exactly how much clearance each side and center then what suspension are you running. Would mainly be concerned about body roll and dive under braking conditions (full brake). How stiff is the car? Only then can someone (not me) do the math to determine if it is too low. I hear you. ...I did not lower the car just replaced standard GT valence with 914 Rubber "sheridan" front spoiler. This is how the car ran for many years prior to my ownership. I was thinking of taking it back to the configuration it ran as well as bringing it back to Irish Green. I'm afraid with the 15's I run on the car may be too lower the car a bit too much. I still have the 16s... so we'll see. ![]() ![]() |
slivel |
Old car....... older driver ![]() ![]() ![]() Group: Members Posts: 528 Joined: 10-July 04 From: San Diego Member No.: 2,332 Region Association: Southern California ![]() |
Yes, you are likely to damage the front spoiler if you use the curbs. On some tracks the curbs are several inches tall. Also you will have to use ramps when loading and unloading from a trailer.
Another consideration is that you will be changing the balance of the car especially if the spoiler was added without a corresponding change in the rear of the car. I added a splitter to the front of my car and was surprised at the handling change. You may be correcting an imbalance or you may be aggravating a problem. I had a nice splitter on my car but it ripped off in a race at Buttonwillow when I got a little too aggressive with the curbs. Never put it back on. ![]() |
wndsrfr |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region ![]() ![]() |
jmz |
PlaysWithCars |
Senior Member ![]() ![]() ![]() Group: Members Posts: 532 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest ![]() ![]() |
OP ( @jmz ) - sidebar question: looks like you have an 15x8" wheel on front? What size Hoosier is on there? 245 maybe? Looks tight to the fender lip. I'm about to try a set of 245 A7s on 8" wheels on the front of mine and hoping you'll say "no problem. Mine fit fine."
jmz |
OP ( @jmz ) - sidebar question: looks like you have an 15x8" wheel on front? What size Hoosier is on there? 245 maybe? Looks tight to the fender lip. I'm about to try a set of 245 A7s on 8" wheels on the front of mine and hoping you'll say "no problem. Mine fit fine." My car has wider than normal GT flares. |
jmz |
@PlaysWithCars
I will say this. Although my car has what I think some call the nurburgring flares that are a bit wider than normal GT flares, I run a 1" spacer up front behind those 15x8s. ...so even though they look tightly tucked into my fenders there is a bit of room. |
wndsrfr |
wndsrfr |
wndsrfr |
jmz |
Yep, it was low. Not sure if the video will upload. If not I'll link the whole youtube video.
Had to go off in the grass to avoid contact and the air dam was sacrificed. ![]() ![]() |
PlaysWithCars |
Damn. That’s no good. How effective are rubber lipped dams at stopping high speed air? The one I’m running is 3-4” from the ground but it has a rubber lip that flexes so it wouldn’t be as susceptible to damage from an or. I think I bought it from 914rubber.
wndsrfr |
Yep, it was low. Not sure if the video will upload. If not I'll link the whole youtube video. Had to go off in the grass to avoid contact and the air dam was sacrificed. ![]() ![]() It's a consumable... put on another & choose your agricultural driving spots carefully.... |
jmz |
Yep, it was low. Not sure if the video will upload. If not I'll link the whole youtube video. Had to go off in the grass to avoid contact and the air dam was sacrificed. ![]() ![]() It's a consumable... put on another & choose your agricultural driving spots carefully.... Exactly. Already ordered another and a friend had one to give me as a spare. ...all set. Just need to watch out for those pesky mustangs. |
914andy |
Member ![]() ![]() Group: Members Posts: 61 Joined: 23-December 11 From: Nashville tn Member No.: 13,929 Region Association: None ![]() ![]() |
JMZ. Did that car come out of Colorado? It looks very much like the car I used to compete against 25 years ago. Ran against him in SCCA and PCA. Husband and wife team and she was damn near as fast as he was.
Back then 2.8 was the legal limit and no twin plugs were allowed. You might have a dickens of a time trying to run 245's on the front. Great car by the way Andy York |
AZBanks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,064 Joined: 7-December 05 From: New River, AZ Member No.: 5,245 Region Association: Southwest Region ![]() ![]() |
Yep, it was low. Not sure if the video will upload. If not I'll link the whole youtube video. Had to go off in the grass to avoid contact and the air dam was sacrificed. ![]() ![]() ![]() |
jmz |
JMZ. Did that car come out of Colorado? It looks very much like the car I used to compete against 25 years ago. Ran against him in SCCA and PCA. Husband and wife team and she was damn near as fast as he was. Back then 2.8 was the legal limit and no twin plugs were allowed. You might have a dickens of a time trying to run 245's on the front. Great car by the way Andy York Andy, it is the very same car. |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
no one runs a lower air dam/splitter than me!
tore it off going backwards through 5 at Laguna later that day... ![]() |
Lo-Fi Version | Time is now: 2nd April 2025 - 02:25 AM |
