3.6 Engine - Lid Clearance? |
PCA7GGR |
Feb 12 2021, 10:26 AM
Member Group: Members Posts: 252 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Will the stock 3.6 intake clear a closed stock engine lid with cross brace?
“Asking for a friend.” Actually I need to know so that I can make a GT lid with a lightened cross brace or one with the brace removed for a 914 with a 3.6. Thanks Sergio The GT engine lid whisperer |
SirAndy |
Feb 12 2021, 10:59 AM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Will the stock 3.6 intake clear a closed stock engine lid with cross brace? “Asking for a friend.” Actually I need to know so that I can make a GT lid with a lightened cross brace or one with the brace removed for a 914 with a 3.6. Thanks Sergio The GT engine lid whisperer I have a GT lid on mine and that fits just fine. (IMG:style_emoticons/default/biggrin.gif) I'd say a stock lid without the rain tray should work. I did remove some plastic from the throttle body crosspiece that connects the two intakes so i could rotate the TB downward a bit and added a custom elbow for the air filter to get it all fit in there snug. |
ClayPerrine |
Feb 12 2021, 11:02 AM
Life's been good to me so far..... Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I was able to fit the 3.6 intake under the stock lid, so the GT lid should work fine.
Clay |
SirAndy |
Feb 12 2021, 11:03 AM
As you can see from my pics above that small rubber elbow is the highest point on my engine setup and that is the only piece i'd be worried about hitting the engine lid.
I think i actually cut a section of the cross brace from my GT lid but i'm not sure that was really needed. (IMG:style_emoticons/default/idea.gif) PS: I can go down to the garage later and take some pics and measurements |
PCA7GGR |
Feb 12 2021, 11:56 AM
Thanks you gentlemen.
roblav1 |
Feb 12 2021, 12:32 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
After rotating the intake on my early 993 build, the stock engine lid fit fine.
Lo-Fi Version | Time is now: 26th June 2024 - 02:42 AM |
