Engine lid seal |
Engine lid seal |
dt4 |
Mar 6 2021, 08:53 AM
Senior Member Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England |
dr914@autoatlanta.com |
Mar 6 2021, 09:12 AM
914 Guru Group: Members Posts: 7,913 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
full length, also looks like the engine lid to grill welting is missing, and the lid should be painted flat black under the grill portion
StarBear |
Mar 6 2021, 09:52 AM
Senior Member Group: Members Posts: 1,952 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Rear window defroster. Haven’t seen many of them, BWDIK.
dt4 |
Mar 6 2021, 10:17 AM
Thanks George
It’s not going to sit into the channel on the ends so I will start by removing a couple of inches of the internal structure from the seal and see if it will tuck in with that removed |
Mikey914 |
Mar 6 2021, 11:50 AM
The rubber man Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The reason is usually there is crud that gets painted over for just builds up on the ends. This is one of the reasons we made it so the internal material can be removed. The OEM has metal comolded into the seal, not so easy to make accommodations. But in fairness it was designed to be installed when the car was new.
Mikey914 |
Mar 6 2021, 11:51 AM
Nice progress by the way
dt4 |
Mar 6 2021, 12:16 PM
The reason is usually there is crud that gets painted over for just builds up on the ends. This is one of the reasons we made it so the internal material can be removed. The OEM has metal comolded into the seal, not so easy to make accommodations. But in fairness it was designed to be installed when the car was new. Agreed Mark, if I had known that a seal went in there I would have ensured it fitted before painting the car I only realised there was a seal fitted when looking through 914rubber just getting round to fitting all the stuff that arrived from you at Christmas time |
Mikey914 |
Mar 6 2021, 09:14 PM
Enjoy
It looks like you are in the homestretch now. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:36 PM |
