justme |
Member ![]() ![]() Group: Members Posts: 187 Joined: 1-January 07 From: southampton ma atlantic northeast Member No.: 7,413 Region Association: North East States ![]() |
So I got these AA's with a car about 10 years ago. Looks like they were mocked up but never ran.
In an effort to get my long stalled project back on the road I pulled the heads & cyl from the original tired 1.7 I have included the original condition before I cleaned up the rough edged with a little emery work Doesn't overlap with the piston travel and I'm building another motor so this doesn't need to last forever, and I'm cheep and don't want to buy another set of 96's for this tired old gal. What do you (experts) think??? Thanks folks! Attached thumbnail(s) ![]() |
justme |
Here's the bad 1
justme |
Another
burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
NO. If you have to ask.
Bob B |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
There was a time in my life when i would not have hesitated to use that cylinder.
Heck, in my dirt bike racing days, i even "fixed" a burnt through hole on top of the piston (running lean on purpose) by putting a round top carriage bolt though the hole and double nutting the back. Worked like a charm. (IMG:style_emoticons/default/wacko.gif) |
Jonathan Livesay |
Senior Member ![]() ![]() ![]() Group: Members Posts: 742 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None ![]() ![]() |
Mocked up with a BFH?
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
There was a time in my life when i would not have hesitated to use that cylinder. Heck, in my dirt bike racing days, i even "fixed" a burnt through hole on top of the piston (running lean on purpose) by putting a round top carriage bolt though the hole and double nutting the back. Worked like a charm. (IMG:style_emoticons/default/wacko.gif) Maybe they would be OK, but what happened to it!? Also, it is nice to know that our fearless leader is so fearless! |
justme |
Can only guess what happened to it. Dropped from the Empire State Building?
Anyway, I'm only hoping to get 1-2k miles out of it and hopefully without metal digestion:) And other than respect for German design & engineering , I won't need this motor when the one I'm building goes in. WTF, I can show off a vent-a case if the bet goes bad (IMG:style_emoticons/default/huh.gif) |
BENBRO02 |
Member ![]() ![]() Group: Members Posts: 483 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region ![]() ![]() |
Can only guess what happened to it. Dropped from the Empire State Building? Anyway, I'm only hoping to get 1-2k miles out of it and hopefully without metal digestion:) And other than respect for German design & engineering , I won't need this motor when the one I'm building goes in. WTF, I can show off a vent-a case if the bet goes bad (IMG:style_emoticons/default/huh.gif) Sounds like a fun experiment. (IMG:style_emoticons/default/biggrin.gif) |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Or just post WTB one cylinder in the classifieds. That way when you finish the other engine you will have a spare under the work bench for the next project
At minimum check it with a bore gauge. |
Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,993 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch ![]() ![]() |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
I've seen this done on high performance engines to help airflow within the engine case. It is done strategically and to all cylinders.
914sgofast2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 632 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None ![]() |
justme |
Sorry if it wasn't as relevant as all of your 2500 posts in the last 2 1/2 years (IMG:style_emoticons/default/pray.gif) Just wanting to get the teener back on the road this summer:) |
justme |
I've seen this done on high performance engines to help airflow within the engine case. It is done strategically and to all cylinders. I believe Bruce Anderson documented it in his 911 Performance book too. Seeing as mine wasn't too strategic, I probably won't post dyno #'s |
r_towle |
I've seen this done on high performance engines to help airflow within the engine case. It is done strategically and to all cylinders. I believe Bruce Anderson documented it in his 911 Performance book too. Seeing as mine wasn't too strategic, I probably won't post dyno #'s Before I would go further, get a bore gauge and see if it’s round. If it’s round, and it’s not scored up inside, go for it. |
Superhawk996 |
Sorry if it wasn't as relevant as all of your 2500 posts in the last 2 1/2 years (IMG:style_emoticons/default/pray.gif) Just wanting to get the teener back on the road this summer:) I apologise, it was an (IMG:style_emoticons/default/bootyshake.gif) clown comment. Just seemed to me that you already had your mind made up that you were going to use it even if the engine popped in as little as a few thousand miles. Good advice here from other people more productive than my comment was. |
justme |
Sorry if it wasn't as relevant as all of your 2500 posts in the last 2 1/2 years (IMG:style_emoticons/default/pray.gif) Just wanting to get the teener back on the road this summer:) I apologise, it was an (IMG:style_emoticons/default/bootyshake.gif) clown comment. Just seemed to me that you already had your mind made up that you were going to use it even if the engine popped in as little as a few thousand miles. Good advice here from other people more productive than my comment was. No worries 996, As wrenching is just a hobby I do value others opinions. Like alot of us the car won't be a daily and there's another engine on the way:) (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 03:04 AM |
